Would You Do it?
butch | Posted in Construction Techniques on October 13, 2005 04:11am
….. Build a 12’x16′ shed on a
a “floating” slab.
Form a box (12’x16′)out of 2×4’s on top of the ground
square, level and brace. Dig out inside this
box to thicken the edge to 8″ to 10″ deep appox. the width
of a shovel. Add some wire mesh and maybe some visquene
and call it good. Oh and this is the memphis area so frost
level is about 13″.
Comments? Insults?
    artacoma | Oct 13, 2005 04:29am | #1
    Heck ya ........to park my lawnmower, not to live in
    What I would do is either perimeter tile or slope the grade away from the building on all sides
    Rik
  2. jrnbj | Oct 13, 2005 04:30am | #2
    Absolutely, positively..........depends
    (on the soil)
  3. StanFoster | Oct 13, 2005 04:37am | #3
    Butch:    Thats how I built this 18 ft.  x 24 ft. shed.   I built another one that was 12  ft.  x 16 ft  30 years ago and its still doing fine.    I did run 3/8 rebar every two feet both ways.....and did dig down the perimeter to 1 ft.
    Of course the best way is a full foundation....but for just some lawn mowers....and christmas decorations...it will be fine.
    Stan
      Luka | Oct 13, 2005 04:44am | #4
      You built that 30 years ago, and you still only have half of it tarpapered ???;o)
  4. butch | Oct 13, 2005 04:51am | #5
    thanks for the replies,
    anybody venture a guess at how much concrete
    I would need?
    3 yds?
    Is 3000 psi sufficent?
    1. FastEddie | Oct 13, 2005 05:22am | #6
      3000 psi is ok, but spend just a few more dollars for 3500 or 4000.
      A simple slab 12'x16'x full 4" = 2.4 cy.
      If the footer is another 6" deep x 12" wide x 56 ft long = 1.0+ cy.
      Order 4 yards and have a sidewalk or something formed up.
      Edited 10/12/2005 10:25 pm ET by FastEddie
      1. RalphWicklund | Oct 13, 2005 07:54am | #7
        Also find out what the minimum order is. If you need 4 yds and the min. is 5, you're going to pay for a yard you don't get. It only gets worse when the minimums go up. I have one supplier with a minimum of 6 and one with 8.
        I generate a little more good will or attaboys when the customer gets a larger patio, driveway or walkway than expected, even though I have to charge for the concrete.
        1. butch | Oct 15, 2005 03:15am | #9
          We have a company here that has small concretetrucks and the MOST they can carry is 3 1/4 yards.So they fill the bill for this paticulare jobTwo deliveries- 2yds then 1 1/2yds 3500psi large rockjust shy of 400.00. And they deliver sat. no extra charge.
  5. Bing187 | Oct 15, 2005 03:05am | #8
    We do light buildings once in a while on a "haunch" pour such as what you describe. Only thing that would concern me is that @ 3-1/2 " above grade, you're pretty close in regards to bugs and more importantly, splashing rain. Think I'd do as you describe w/the trench inside but I'd form up outside w/ a 2x10, and fill inside w/ appropriate gravel to keep the pour at 5" thick or so.That way, your conc expense doesn't go up, but you can keep the wood around 9" above grade.
    my .02
    Bing
    1. butch | Oct 15, 2005 03:16am | #10
      I appreciate the heads upBut I plan to wrap the structure in tar paperand use hardie siding so hopefully moisture shouldn't be a problemo.
  6. maverick | Oct 15, 2005 03:57am | #11
    Why concrete? You could build it on a pressure treated platform
    1. butch | Oct 15, 2005 04:47am | #12
      Why concrete?That is what the customer wants.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
