I have two French doors to be installed in an upstairs patio. (Will receive light use)
Before I install, I want to evaluate my flashing options.
1. Standard Copper Flashing
2. York 106PT Laminate
My preference is number 2 based on the cost, ease of installation and the fact that I believe I’ll get a better look without renting a metal brake.
Any experience with this product?
Thanks,
JNF
For those trying to figure out what he is talking about.
http://www.yorkmfg.com/yorkShield106pt.asp
It is thin copper laminated to a sticky back plastic.
Bill,Thanks for helping to clarify.JNF
What are your door sills made of?
rebuilt with BCX Plywood.JNF
I used it once, when I needed a flashing in a pinch and my only choices were that or aluminum, on AQC lumber.
I wasn't impressed. The copper layer is super thin and the stuff teats easily. Maybe I had a bad batch but I don't plan on using it again.
Depending on where you live and what the application is you have many options.
get a roll of 8" lead flashing, or measure each rough opening width, add a foot, and buy it from a yard that sells lead by linear foot cut length to width of rough opening plus one foot lay it flat on subfloor bringing it into house (past jack studs) by 3/4" to 1" secure these edges to subfloor w edge only of roofing nail head to protectagaist scuff-up during construction, .e. do not perforate lead w roof nails, just hold it down use scrap block on lead, tapping block w hammer or mallet to flatten to subfloor starting in middle and working to ends crease vertical w block at jack stud to run vertical 6" very malleable, easy to work, no brake needed, no sharp edges, lasts forever even in salt air climate set door and install 3/4" to 1" that extended into house past jack studs gets folded up just prior to underlayment/tile or finish flooring install the side wings at jacks then get folded into r.o., forming a 45 degree crease on both ends like hospital corners on a bedsheet this creates a vertical curb flashing across the entire opening against wind driven rain, it can only run out
