zero degree wood
redtoolbox | Posted in General Discussion on February 9, 2007 05:30am
I am building a book shelf, for a customer, out of maple plywood in a my garage which is unheated. My question is how much will it expand when I take it inside to install? It is a modern design which involved inserting the supports in the center of the shelves. Which means I routed out a 3/4 inch hole for 3/4 inch lumber. Should I plane down that lumber and by how much?
Thanks, RTX
  1. BillBrennen | Feb 09, 2007 05:35am | #1
    Don't worry about it. Check your support wood to be sure it is really 3/4". The movement due to temperature is too small to matter.
    Bill
    RichBeckman | Feb 09, 2007 05:57am | #2
    If you don't get an answer here, try over at Knots.
    http://forums.taunton.com/fw-knots/
    Rich Beckman
    This signature line intentionally left blank.
  3. Piffin | Feb 09, 2007 06:09am | #3
    wood cahnges size due to moisture, not temperature. Well, maybe temp makes some difference, but not enough to notice for our purposes.
    1. DougU | Feb 09, 2007 07:23am | #4
      Right, and along with that the material of choice here is plywood so wood changes will be miniscule.
    2. redtoolbox | Feb 09, 2007 04:37pm | #8
      Thanks for your help.
      redtoolbox
    BillHartmann | Feb 09, 2007 07:58am | #5
    "It is a modern design which involved inserting the supports in the center of the shelves. Which means I routed out a 3/4 inch hole for 3/4 inch lumber. Should I plane down that lumber and by how much?"
    You need to explain this some more.
    From the first sentence I was invisioning it being a "float" or "hidden support" shelf. For those you have a posts that sticks out of the wall and the there are horizontal holes in the self that slide over the post.
    But for that, you clearly can't have a 3/4" dis hole in a 3/4" thick self.
  5. frenchy | Feb 09, 2007 02:23pm | #6
    redtoolbox,
      plywood doesn't swell as much as solid wood will.  wood swells due to moisture not temps and plywood because the direction each layer is laid at is opposite it will shrink and swell the least...
  6. sharpblade | Feb 09, 2007 03:06pm | #7
    Not to split hairs, but is your plywood exactly 3/4" thick?
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
