zip wall for home use
Hunter8it | Posted in General Discussion on January 6, 2008 05:12am
I would like to find a dust barrier product like the Zip Wall product, but would prefer one that can be permanently installed with zippers or some kind of quick install system. Does anyone know of a product like this?
Thanks.
  1. jimblodgett | Jan 06, 2008 05:43am | #1
    I recently tried the Zip Wall brand zippers for the first time and I'm disappointed.  The zippers they sell at Home Depot are a lot better.  Wider flanges on the sticky tape and the hole in the flapper is nice to tie the shoe strings through for double zippered openings.
    Probably not what yoiu're asking about, but I just thought I'd share the experience.
    Ever wonder why "holistic" doesn't start with "w"?
  2. gordsco | Jan 06, 2008 05:46am | #2
    If this is for a home shop, maybe  a curtain on a track. It would take seconds to close off an area.
    It won't stop all but would be pretty good if there was some sort of negative pressure/ dust extraction/ air cleaner on the inside.
    Gord
    JDRHI | Jan 06, 2008 05:56am | #3
    Can you be a tad more specific regarding its purpose?
    When renovating my own kitchen, I framed a panel using 1 5/8" metal studs, an inch or so smaller than the entranceway. Wrapped it in 4 mil. poly, and adhered that foam pipe wrap all the way around the perimeter. Popped it in and out of the opening as needed.
    The snug fit kept every dust particle contained.
    J. D. Reynolds
    Home Improvements
    1. Hunter8it | Jan 06, 2008 06:11am | #4
      It's for a home workshop in the garage, but I have to share it with household storage. I use a vacuum system but still lots of dust gets by. If I could seal myself into half the garage when I work it would solve the problem but a zip wall is too much work to put up and down evry time I use my shop for an hour.
      1. natedaw | Jan 06, 2008 06:15am | #5
        i've made portable barriers using emt conduit before. works great and cheap too! don't waste your money on zipwall products if you plan on having a zipper in the wall.
        JDRHI | Jan 06, 2008 07:00am | #6
        Do you use the garage as a garage....for cars?
        If not, could you build a partition wall dividing the space to suit needs? (With the intention of tearing it down should the time to sell arise.)
        J. D. ReynoldsHome Improvements
        1. Hunter8it | Jan 06, 2008 07:24am | #7
          I don't use it for cars, but it is nice to have to open space. For example, if I have a removable plastic wall I can use the open space for finishing (after the dust settles) or glueing. If I separate it into two rooms permanently I won't have much working room. Also it would be nice to be able to drop the curtain or wall now and then when I am trying to feed an extra long piece into my table saw.
          1. maverick | Jan 06, 2008 07:04pm | #8
            sounds like a couple of canvas painters tarps would work better for you, and last longer. just rig something to hoist them out of the way when not needed
Build a Transom Above a Stock Door
A decorative transom fills in the space between a stock door and the home's 9-ft. ceiling, saving the cost of a custom door.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
