1hr fire rated jams?
ponytl | Posted in Construction Techniques on December 11, 2004 06:22am
how do you guys deal with metal jams that hang 1 hr rated wood doors set in wood framing…ie: 2×6 wood stud wall 5/8 rock on ea side of wall…    one piece frames or split metal frames?…  most that i’ve dealt with were 1pc where u slid the drywall behind the metal and just caulked the edges….  which means we set the jams first and framed to em…  ideas? i have 20 of these to do….
as always thanks in advance
pony
started out with nothing and have most of it left
? can you build/use a wood jam and get a 1hr rating? just curious
  1. buildit4you | Dec 11, 2004 08:39pm | #1
    ponyti,
    I use knock down frames. Two sides and a head. The frames come with clips that snap into the bottom of the jambs and you run several screws into the framing, drywall and all, the baseboard will hide the screws. Then, there is an adjustable expander at the top on both sides that adjusts the frame plumb. (it pushes against the framing behind) I've hung hundreds on them. If you want a manuf. I may have a website for you.
    Hope I helped. Also I think you only can get 30 mins. with a wood jamb. Not 100% on that though.
    Good times, riches and Son of a _itches
    I've seen more than I can recall.
    J. Buffett
    1. ponytl | Dec 12, 2004 08:44pm | #2
      cool deal... yeah if u have a web site that'd be cool... i assume they make a jam that'd cover 7" wall thickness   2x6 wall   5 1/2 + 5/8 +5/8 ?  do u frame the rough opening tighter than u would for all wood?  on a few commerical deals i've done we used the 1pc jam  set the jams first fastened to the concrete floor then built to em... slid the drywall behind the jam and caulked....
      son of a son of a sailor....  can't tell u how many times i've listened to that song while ride'n my bike down to the keys...  nothing like cruise'n down the 7 mile bridge water on both sides warm ocean breezes...shorts & a teeshirt know'n it's 20 degrees back home...good friends all grin'n know'n that life is good....
      pony
Ranch Redux
An architect and a handy homeowner team up for an exterior upgrade with energy efficiency, comfort, and durability as part of the plan.
  • Beat the Heat: Cool Innovations
  • A Practical Approach to Exterior Insulation
Start your subscription today and save up to 81%
