addition to a mobile home
mikecar | Posted in Construction Techniques on May 15, 2006 01:53am
Hello, my name is mikecar. I’m new here and would like to get some help from you guys. I’mputting an addition on a 12×60 mobile home that has a 12’x20’porch room on the side of it. It has it’s own private septic with town water.There has been no problem in the past with frost raising and lowering the home and screwing with pipes and drains. we put the footings in and am waiting for the walls to go up soon as it stops raining.I’m just thinking if theres going to any problems with an addition that has a full basement/walkout joined to a “floating home”.If it does “float” at all. Any  Input out there?
Edited 5/14/2006 7:16 pm ET by mikecar
  1. rez | May 20, 2006 11:36pm | #1
    Greetings mike, Welcome to Breaktime.
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    half of good living is staying out of bad situations
  2. YesMaam27577 | May 21, 2006 02:41am | #2
    Its really hard ot say without LOTS more details. But one area that comes quickly to mind is the point at which the new and old roofs are joined.
    Unless you're the lead dog, the view just never changes.
  3. hasbeen | May 21, 2006 05:25am | #3
    You might add in what sort of climate you live in and what sort of soils you are living on, the type of foundation you plan to build, and what the mobile sits on now.
    You can do it, but it may not always be what you'd hoped for.
    "Doubt is not a pleasant condition, but certainty is absurd." Voltaire
    1. mikecar | May 21, 2006 08:04pm | #4
      Gravel,gravel,and more gravel.The whole thing is on gravel that was trucked in 10-15years ago. The mobile home is on solid blocks every 4-5ft. supporting the frame rails. Town water with private septic system,there's been no problems with pipes under the home,or any sign of lifting with frost. We are in cenrtal Massachusetts, I think with the dry gravel base there's no frost heaving. Addition roof is 90degrees to the home roof with a valley and then running with it and over the porch roof to the end of the porch. New rafters added from outside wall of porch to the peak of the home with a short wall at mid span being the outside home wall. Metal roof over all of it.
      1. hasbeen | May 21, 2006 09:01pm | #5
        Where I live it's required that mobiles be set on a "strip footing". It's not under the perimeter. It's under the support beams, must be mono poured with rebar, and the metal mobile frame must be welded to the footing (usually with rebar, sometimes with log chain).No one can tell you ABSOLUTELY whether or not there will be different movement between old and new. If it was me, I'd probably just go for it.Best of luck to you.++++++++++++++++++++++++++++++++++++++++++++++++++
      2. Danno | May 21, 2006 11:38pm | #6
        You are right about the gravel preventing frost heave. If you're on gravel like you say, I wouldn't worry about the old "floating" away from the new. But, I am not an engineer.
  4. user-144854 | May 22, 2006 04:39am | #7
    Last time I did this, I extended the basement under the mobile home to the frame rails, and replaced that section of piers with an 8" CMU wall on a strip footing contiguous with the rest of the addition.
Drafting the 2027 IRC
  • The New Old Colonial
