Advice wtd Opening a basement wall +more
I am about to undertake a project that I would like some advice on. Here is the situation. I have recently purchased a house with a basement that has 12 inch thick concrete walls that are only 6 ft tall. The basement also has a dirt floor. There are no external openings. I would like to cut open a 6′ bulkhead and use a crawler to dig out some more of the basement floor. I will then pour a cement floor to have an approx 7.5′ high ceiling. The exterior of the house is cinder block with brick outside both riding on top of the foundation. I am planning on cutting a 6’wide opening on the side of the house. Here are my questions. Before I cut the opening I am planning to install a lintel that is 8′ long on top of the foundation wall. Should the lintel be steel? How thick should it be? I could also probably have a box steel beam fabricated which I think would be better. I could also stack together 8′ PT wood beams but I am leaning towards the steel. I am going to cut the lintel opening and install the lintel in a matter of hours, but for some period of time the brick and cinder block above will be unsupported. I cannot think of a good way to carry the load while working there. I think it will be ok for the short period of time but I don’t know for sure. Does anyone have experience with this or advice to offer?
Many thanks, Projectman
how far down are your footings?
bobl Volo, non valeo
Baloney detecter
The footings go down another foot. I will cap them to prevent undercut, but i have to get in there first by cutting the outside opening. Any ideas on the lintel?
