Angle Grinders
msw | Posted in Tools for Home Building on July 21, 2008 08:44am
I am trying to buy an angle grinder that is easy to move and not heavy.  I will be mainly using it for woodworking.
Is it 4″ or 4.5″ easily available?
Thank you.
Moataz
    boiler7904 | Jul 21, 2008 09:36pm | #1
    4 1/2" tends to have the most accessories available.
    If you're going to be using it cut tile or stone, take a look at Bosch - they just introduced add on guards for their newer 1800 series grinders that have built in dust extraction ports.
  2. DavidxDoud | Jul 22, 2008 12:09am | #2
    4" generally have a different arbor size than the 4.5" - get the bigger -
    I have two milwaukees I use for woodworking, including 'Lancelot' chainsaw style cutters - I'd recommend the paddle switch like the Milwaukee's have if you are going to be using anything other than abrasive disks -
    "there's enough for everyone"
  3. inperfectionist | Jul 22, 2008 02:36am | #3
    Get a 4.5",,,, arbor is more common.
    I have a few,,,, and the next one I buy will be variable speed.
    Variable speed would be a big plus for your application.
    I do not like the paddle switches,,,, seems other people do.
    You'll have to see what your comfortable with.
    Brands ?? I would lean toward Makita or Metabo. I saw a Fein that looked interesting,,,,
    Watch out,,, these things can bite you!!
    H
    JeffBuck | Jul 22, 2008 07:15am | #4
    easiest to control ...
    the 4" makita.
    great little grinder.
    I also have a 4.5 milwaukee that's for the actual grinding work.
    the 4" makita is was more comfortable and easier to control.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. gfretwell | Jul 22, 2008 08:49am | #5
      I am another fan of the 4" Makita. I have had one I have been abusing for 12 years. I also have a 5" Hitachi that is pretty tough.
  5. reinvent | Jul 22, 2008 03:42pm | #6
    I think the Metabo grinders are some of the best made. And you can change the disk's without tools.
    http://www.cpometabo.com/products/600715420.html
    http://www.metabo-anglegrinders.com/Metabo-Compact-Class-Angle-Grinders-Product-Feat.23034.0.html
    1. peteshlagor | Jul 22, 2008 03:49pm | #7
      I second that.
      So sweet, a gurl could use it and not damage her fingetnails.
    2. DougU | Jul 23, 2008 05:31am | #9
      I dont think I have used a tool to change the disks on my grinder for over 5 years. Just grab the disk and hold the lock button down and turn the disk - works like a charm! Dont even know where the tool is anymore.
    dedhed6b | Jul 22, 2008 03:56pm | #8
    I thirdzees the 4" Makita.Light weight and and good on/off control. Great for scribing and coping.
  7. badarse | Jul 23, 2008 07:18am | #10
    I love my Makita, not sure of the model.  I use a rubber backer for woodworking discs, which is what I use it for most.  Its light weight and well balanced.  The trigger runs the length of the body which makes for great one handed use while holding your work.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
