Good Day
Are there any good methods of attaching 4×4 posts to a roof deck using 2×4 sleepers under the deck?
I would prefer to cut through the roof and attach to the porch rafters below..
thanks
HD
Good Day
thanks
HD
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
That makes for the strongest posts generally, but creates a point of entry for water and increased costs to flash it properly.
I like to know my layout, and place a PT 2x12 blocking( for something to lag into) in between the sleepers where the post locates, then deck over with the IPE` or other decking material.Then I do the post with torsion box type hardware. Basicly, this places a threaded rod up the center of the post that is tightened down with a nut at the top, just under the post cap. Several of the PVC type post and rail companies have the hardware, as does Fypon.
Let's see if I have a sample photo...Yep, this one is a replacement where I anchored it to crete footing with epoxy - and another over a Tendura deck
Edited 3/28/2008 5:10 pm ET by Piffin
Piffin, a couple of questions about your pictures:Do you have the plates with captive nuts made up or are they a purchased item. If purchased, where do you get them?Do you use solid or box posts? If solid, to make room for the threaded rod, do you use a really long bit or saw them in half lengthwise and make a groove and glue them back together, or some other clever approach.What kind of threaded rod do you use: Plain, plated, stainless? Thanks, Al
What you see there came from Fypon. It is galvanized already made up with the threaded nut welded into a base plate. you could probalay make up the same yourself if you have a welder. Alignment is critical though. The threaded rood is simply a standard six foot length of all-thread. You can buy this kit from Fypon distributors without buying their posts. I think the other company I got from was Weatherbest composite railings. I have used the Fypon with my own posts also. The posts are hollow box-type.
