Automatic Gate Operator
adirusso | Posted in General Discussion on January 21, 2006 02:10am
I have a customer with a pair of 18 foot ( 9 foot each gate ) wrought iron gates that he wants to put on a automatic operator.  Of course, he would like something that is fairly small and easy to look at .
Does anyone have any experience with a particular manufacturer or distributor for this item?
Thanks,
AD
  1. calvin | Jan 21, 2006 02:33pm | #1
    Fence and on occasion, automatic door co.s (garage) can put you together with something that could work.  Pay particular attention to the Posts the gate will swing on (or consider rolling gates if possible with your design).  If you can fix a bearing on a spindle operation will be easier.  You won't need a big motor, but a solid post is key.
    How heavy are these gates and where do you live.  Snow?  Coastal with salt spray?
    And welcome to Breaktime.
    Quittin' Time
  2. artworks | Jan 21, 2006 04:31pm | #2
    look at FARM SHOW  magazine, seen few openers rigged up for gates . may have to check back ishs. lots of farmers are pretty good @ inventing and are willing to share. Thinking about doing same for myself as I have half dozen reclaimed OH door openers at my disposal. There is probably a specialty Co. that does that sort of thing, with all the 'gated' communities springing up, but probablt much $$$$.  Good luck.
    IF IT WAS EASY, EVERYONE COULD DO IT!
  3. VaTom | Jan 21, 2006 04:59pm | #3
    The opener is the simple part.  http://www.surpluscenter.com/sort.asp?UID=2006012107354330&catname=&byKeyword=yes&search=linear%20actuator is a decent selection.
    The trip is a little more complicated, light beam, infrared, magnetic vehicle sensor...  My vote, and use, is the magnetic sensor.  Have one buried in our driveway for 8 yrs.  Zero falses, unlike the others.  Here's a description http://www.gate-opener.com/gto_exit_wand.html
    If you want a kit: http://www.northerntool.com/webapp/wcs/stores/servlet/NTESearch?storeId=6970&N=0&Ntk=All&Ntt=gate%20opener&Nty=1&D=gate%20opener&Ntx=mode+matchallpartial&Dx=mode+matchallpartial
    My interest was an automatic closer.  Part of my security arrangement after a problem a few yrs ago.  Now, the gate closes after entry.  Doesn't open until disabled, not automatic.  My driveway sensor does double duty as also an annuciator several hundred ft down the driveway.
    BillHartmann | Jan 21, 2006 05:25pm | #4
    If you want an installed unit look at Chamberlain dealers.
    http://www.chamberlain.com/corp/chamberlain_prod_fam/
    They have units under the both the Chamberlain and Liftmaster brands. And units for smal man gates upto the larger commercial applications.
  5. ponytl | Jan 21, 2006 08:56pm | #5
    you might check on ebay... alot of new ones listed... GTO is one brand thats pretty good...  as others have stated  the post is where it's at...  it's all balance and bearings... if done well they work well...   last few gates I've built I've used trailer axle stubs and hubs & bearings for the the lower pivit point & support.. (less than $40 online and if u live in a salt area u can find galv) and a 1" hiem (sp) end on the top for adjustment...  with tweeking you can get a 1000lb gate to swing will a few lbs of force...
    p
  6. BoJangles | Jan 21, 2006 11:34pm | #6
    I am in the process of installing a Liftmaster system on gates the same size as yours.  They are very heavy duty and somewhat complicated in setup, but appear to be very well designed and built.  These require 220 volts.
    You can get many options for the openers.  This customer has chosen every one as I see it!!  You can get push button towers, remote radio units, underground wires like you see at traffic lights etc. etc.   I have about 1000# of parts with no coherent directions as to how it all goes together, so I am doing a lot of reading and planning.
    All of the materials appear to be of very high quality.  I think he probably has about $2000 tied up in materials so far.
    You will need an opener for each side of the gate. These are very hefty units and must be placed in precisely the right spot in relation to the gates.  You will have to install a plate of some sort on the gate to attach the opener arm.
    The operator units are about 12" wide x 18" long x 12" high and must weigh at least 200# apiece.
Podcast Episode 695: Saving Bricks, Cut-and-Cobble Insulation, and Waterproofing Foundations
Listeners write in about paint strippers, bricks, and FHB Podcast volume and ask questions about insulating under membrane roofs and whether waterproofing prevents concrete foundations from drying.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
