I have felled a few trees but I have always had a chainsaw with the blade longer than the width of the tree. I would like to take a stump down from 6 feet high to as close to the ground as I can. Unfortunately, the biggest chain saw I have with me is a 20″ Stihl Farm Boss and the stump is about 23″ in diameter. I suppose I could knotch the stump so that the width would be narrower, but I was wondering if there is a reasonably safe way to cut through a tree trunk with a short saw and not run into danger from the saw kicking back?
as you cut around the trunk add spliting wedges behind the the saw bar...
pound them in as you go deeper with the saw..
WOW!!! What a Ride!
Edited 10/27/2006 12:37 am by IMERC
I've never had trouble with kickback in that situation- it's when the bar tip suddenly hits something you weren't expecting that you get kickback. Position your body so that the kickback won't take itself into your face, as a general rule.
Usually when you're cutting something bigger than the bar like this, you can dig the dogs in to the tree, pivot the saw in until you get close to the tip, then pull the saw back around, dig the dogs in again, and continue. Picture the chainsaw rotating around the log handle first.
By the time you've gone 90º or so, you only have about 2/3 of the log left to cut, and so on. Like Imerc says, use some wedges in there after you've cut a good chunk of it away, so the saw doesn't bind up and kick out.
zak
"so it goes"
If this is a one time "project" go to the rental center and get a bigger saw. For $20 or $30 you get the stump sliced off close to the ground, nice and flat, without the kickback concerns.
Don't forget to yell...STUMP!!!...when it's about to drop. :) :)
Zak said it. I have felled and cut up many larger trees with my JD 18" bar. The secret is not to let the tip catch past the point of where the chain is going the wrong way thus drawing...or 'kicking' the saw back towards you. Learn to dig in and work your way around and definately use wedges as you go. Think about the mechanics of where the stresses are occuring while you are cutting and stop to remedy any situation that would cause kickback or binding.
I remember once learning a hard lesson about sawing through too far before the kerf closed in on the saw and the entire weight of the large tree bound the saw so that it would not pull free. I had to get my 4x4 truck and a rope to pull the tree over and free my now damaged saw. The tree was biting back.
I have two chain saws. Keeps me from going after the rope and truck or tractor when I get one hung up. I generally get it right the second time <g>
Should be able to drop a 40" tree with a 20" bar.
