In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Basement Insulation Products
NPitz | Posted in General Discussion on August 19, 2002 10:39am
Am I crazy or do I recall discussion back on the old board about a rigid foam basement insulation system (interior)that is pre-grooved for furring strips? Maybe I am not recalling correctly, but I vaguely remember somebody (Gabe Martel, I think) discussing something along those lines. If anybody is familiar with this (or any other good system) please let me know.
Edited 8/19/2002 3:41:36 PM ET by Nick Pitz
  1. Gabe | Aug 20, 2002 12:55am | #1
    Yes Nick it was discussed at lenght and you may want to check this site out first.
    http://www.dow.com/styrofoam/na/dowpro/builder/new/prodctr/intc.htm
    Gabe
    1. NPitz | Aug 20, 2002 12:58am | #2
      Thanks, Gabe, that's just what I was looking for. Nice to know I remembered correctly.
        rjw | Aug 20, 2002 02:06am | #3
        I've seen that stuff somewhere.  Wondered where you'd get lath straight enough to match the grooves!
      2. Gabe | Aug 20, 2002 02:44am | #4
        You're welcome.
        Gabe
        1. xMikeSmith | Aug 20, 2002 02:53am | #5
          nick.. we've been insulating our crawl spaces and basements with Performguard EPS. (3" ) with 1/2" OSB.. the Performguard is treated with borates.. about R20... paying about $45 for a 4x8..
          the only thing left to insulate is the 12x12 space on top of the foundation which we do by drilling thru the subfloor above and blowing cells in thru a 1" nozzle..Mike Smith   Rhode Island : Design / Build / Repair / Restore
          1. xMikeSmith | Aug 20, 2002 02:56am | #6
            notched around the joists and shoved up against the subfloorMike Smith   Rhode Island : Design / Build / Repair / Restore
          2. NPitz | Aug 20, 2002 03:38am | #7
            Looks interesting. Are you getting it from an SIP manufacturer or a local place? And how are you attaching it to the basement walls?
            This is going to be a full basement under an addition we're about to start building. It will be radiant slab with 2" styrene under, and 12" block walls with 40 mil self-adhesive bituthene waterproofing. Eventually it will be a spare bedroom, so we are going to insulate and drywall it, and that's it. I'm still grappling with the problem of having two vapor barriers. I'm not worried about water, between slab drains, footer drains, bituthene, and gravel backfill water shouldn't be a problem, but I don't want to trap any moisture between the bituthene and the interior foam. Fiberglass is out of the question, and I suppose I could wet spray cells, but I think that might be a little bit overkill.
            Edited 8/19/2002 8:39:30 PM ET by Nick Pitz
          3. xMikeSmith | Aug 20, 2002 04:18am | #8
            all of our foam comes from Branch River Foam.. which i learned about here two years ago...most of the EPS guys are associated with  R-control, as is Branch River .. some kind of franchise or licensing parent...
            they can bond blueboard, cement board, osb.. or anything else you might want..
            the floor system above locks in the top and the concrete slab locks in the bottom.. in this case we only have about 8'2 from the sub-slab to the bottom of the subfloor above.. in a normal basement we could order 9' high panels and do the same thing..
            or use the 8' high panels and block the top differrently..
            here's the same job with a 3" panel and blueboard helping us make the transition from the cathedral ceiling area to the area above the old attic...
            forgot the link for R-Control..
            http://www.r-control.com/
            Edited 8/19/2002 9:46:17 PM ET by Mike Smith
            BillHartmann | Aug 20, 2002 11:14pm | #9
            BTW, my local Lowes store has R-control sheets in 1/2 and 2" if I remember correctly.
Hassle-Free Window Screen
This retractable screen from Pella maximizes convenience and function.
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
  • Linda Reeder: Architect, Professor, and Author
  • Podcast 458: PRO TALK With Glue Expert Bob Behnke
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
