Need to replace two windows that were installed during original construction. The house is sided with clapboards that butt up to the casings. Need to cut (remove) them back to properly flash the windows.
Would you remove them all the way back to their last seems or cut them back in a straight line parallel to the window. I am figuring 6 to 8 inches back around the perimeter of the windows. Any tips, or tips will be appreciated.
Fine Homebuilding Recommended Products
Cepco BoWrench Decking Tool
This tool makes straightening deck boards a breeze during installation.
Peel & Stick Underlayment
Often required by code, this durable, slip resistant, self-sealing, and self-adhered roofing underlayment is easy to install and ensures maximum protection along roof eaves, rakes, and valleys.
MicroFoam Nitrile Coated Work Gloves
These gloves are comfortable and have a good grip, making for splinter-free work.
Protective Eyewear
Eye protection is a must, and these are designed for comfort so you can can wear them all day long without pain or fatigue.
Roof Jacks
All-steel construction makes these roof brackets durable and long lasting, and their adjustability allows you to create a flat, safe standing surface on most any pitched roof.
Pull to the nearest seam, otherwise you just created a great big line of butt joints next to the window. Unsightly is probably even less of a concern than the idea that you just created a new place for water to get in, making the whole exercise rather pointless.
Leave them right there, and just work them loose and remove the nails from them. That way you can work new tarpaper in behind them
