Blending an SEP
mwgaines | Posted in Construction Techniques on February 5, 2007 01:38am
As part of my remodel, I’m moving the SEP indoors (just think it’s better off not exposed to the elements). That being said, I’d also prefer to place my meter base and SEP back to back, but that will require me to locate both on a kitchen wall to accomodate the service drop from the pole.
Is there a creative way to blend the SEP into a kitchen environment? I know the code prohibits putting it in a closet or cabinet, and I’m aware of the distance requirements around the opening. I obviously don’t want to interrupt a run of cabinets, so I need to place it on an open section of wall, or maybe on a perpendicular wall, like the oven cabinet or a wall enclosing the refrigerator.
I don’t want the metal cover showing since that would detract from the aesthetics of the room. I’m sure there’s a way to camouflage the SEP, but not sure if that would violate the NEC (I’m thinking the only thing worse than limiting access to an SEP would be to conceal it so well that it couldn’t be located in an emergency).
Anyway, I really need to put the SEP somewhere in the kitchen area without violating the code and without creating a big eyesore.
Any ideas?
Michael
New knowledge is priceless.
Used knowledge is even more valuable.
  1. Stuart | Feb 05, 2007 03:03am | #1
    I don't think you'd have any problems with the inspector if you have a framed picture or print or something like that mounted over the door of the panel.  I've seen it done where the picture frame had a couple hinges on one side and a magnetic catch, so it can be easily swung open for access.
    This would be a good time to consider moving the service entrance from overhead to underground, if it will fit in the budget - then you don't have to stay in line with the service pole (you could maybe move the meter around the corner of the house) which may help with the location of the panel inside the house.
  2. JTC1 | Feb 05, 2007 11:51pm | #2
    A great camo for SEP in kitchen? Sorry don't have one.
    The pure underground option mentioned will be pricey or labor intensive, but could move the SEP out of the kitchen.
    An alternative to above is a "partial underground" meaning that you maintain the existing overhead service feed from the pole which drops down to the meter pan, from there go underground in conduit to whatever location you want around the perimeter of the house.  Check with the local utility / building department, but this type of arrangement is OK here in Delaware.
    Our local HfH has done this on several houses for various reasons.  Advise the use of PVC conduit as opposed to direct burial cable - makes life easier should there ever be a problem or upgrade needed. Further, don't be skimpy with the conduit size - bigger is easier and not that different in price.
    Jim
