Here is what happens when there is insufficent thinset under a floor tile, and a heavy load is rolled across. 18″ porcelain tile on a concrete slab, moving in a small safe on a pallet jack. Maybe 5000 pounds at the most. Yes, it might have been prevented with a layer of plywood, but that should not have been necessary.
“Put your creed in your deed.” Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.” T. Roosevelt
Now for the 50 cent question........
Got a spare tile?
Yes = no problem
No = worm can
Jim
Half a box of spares."Put your creed in your deed." Emerson
Not so bad then!
I certainly would not have expected a tile on concrete to break either.
Of course that void underneath it did not help.
JimNever underestimate the value of a sharp pencil or good light.
Many of the larger format porcelain tiles have a concave back. You have to use a larger trowell and back butter them.
Replacing the tile will be easy. Matching the grout will be a challenge unless the leftover was saved.
Anybody who rolls a safe on a pallet jack over a tile floor without protection should expect to regret it!!!!!
I used to do the final inspections for a big shopping center developer and they were a little picky about tile setting in the main areas. We were instructed to use a golf ball and walk a grid pattern while bouncing it. Man, can you find the voids easy that way! Instead of the distinctive sharp DINK you got a dull DOWK. Never failed.
From your pix it looks like there wasn't a full mud back. The concrete looks spaled as well. Good luck with that.
ciao, ted
I like that ...
I usually just knee and knock.
after a while the knuckles hurt.
Jeff Buck Construction
Artistry In Carpentry
Pittsburgh Pa
think ya would have stoped rolling when the 1st few broke and dealt with it....
or you needed more work...
or yur attitude to the client is showing...
WOW!!! What a Ride!
What? Only one tile was broken. Clean yur glasses."Put your creed in your deed." Emerson
Porcelain tile has to be set on a solid bed, this means buttering the back of tile as well as a good bed on the sub floor. Its cheaper to use a couple more bags of tile adhesive than to have tiles popping or cracking and then getting a call back from the client.
I broke a tile by kneeling on it! Guy I work with that laid the tile was unhappy with me, but I figured it would have broken eventually--it had a void under it--and it was better me than the homeowner.
5 Thousand Pounds suspended on probably 4 small points?????
1250 pounds each???? Lucky thats all it broke....
Bud
