I’ve got someone who wants me to build 2 fairly large built in bookcases. I’m wrestling with my concern for a perfect fit (build on site?) vs the convenience of building them at my shop although they are big enough that space will be tight. If I build them here and transport them it will have to be in sections. Be happy to hear any opinions…
Paul
I try to design all built-ins of any kind as single or multiple carcase components that are shop-built. Then I deal with the "site" variances by field-fitting the scribed front trim elements.
That's sort of what I was thinking Bob... I just haven't done enough large case pieces to have a good feel for what's less work in the long run. Thanks!
What I do is get as complete a set of site measurements as possible, scoping out all the wall, floor, or ceiling conditions that will come into play when the built-in is installed.
Then I design and shop-build, and the facing parts are all biscuited, or doweled, or pocket-screw prepped, so as to assist registration and assembly on site.
I get the scribe parts as close to real width as I reasonably can, then back bevel the scribed edge, so all it should take in the field is a little work with a block plane.
Very good advice Bob... I appreciate it!
I'm building an entertainment center with a matching book case, they go on either side of a fire place.
They are approx. 9 feet high. I will have 4 components for the entertainment center and three for the bookcase. I'm building the face frame as one large piece, it wont be very heavy.
Take it all out there, assemble the carcasses add scribes, add the face frame and presto, your done.
I have worked on about 20 entertainment centers in the last 4 or 5 years, we did all of them in components. So much easier.
Thanks for the reply Doug... You guys convinced me ;)
