buzzing dimmer switch, why?
bchanson | Posted in General Discussion on February 16, 2007 12:01pm
so i’ve got a client with some buzzing can lights on a dimmer switch. i understand the buzzing comes from the filament in the bulb vibrating due to the fact that the dimmer is cutting the current down. getting a new dimmer seems to be the key to fixing it, but can anyone suggest a style or brand that is immune to this problem? The current dimmer is a home depot Lutron model. Thanks for any suggestions.
brad
    IMERC | Feb 16, 2007 12:42am | #1
    switch is overloaded and getting too hot...
    WOW!!! What a Ride!
    1. bchanson | Feb 16, 2007 12:55am | #2
      there are six cans each with either a 50W or 75W bulb (i can't remember at the moment). would this much load really be overloading a dimmer?
      1. Stuart | Feb 16, 2007 12:58am | #4
        Yes, the dimmer could be overloaded.  They usually have a label on them that says how many watts they can handle.  You're talking at least 300 watts and probably more, and some dimmers are rated for 300 watts or less.
          IMERC | Feb 16, 2007 01:02am | #7
          even a 600W switch could be overloaded....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
        IMERC | Feb 16, 2007 01:00am | #5
        yup...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
    2. JMadson | Feb 16, 2007 12:56am | #3
      Are the lights buzzing or the switch itself?“The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
        IMERC | Feb 16, 2007 01:01am | #6
        DIIK...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
        1. JMadson | Feb 16, 2007 01:14am | #9
          DIIK?“The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
          1. highfigh | Feb 16, 2007 04:08am | #15
            Danged If I Know.
            IMERC | Feb 16, 2007 04:31am | #16
            somebody has to...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      2. bchanson | Feb 16, 2007 01:05am | #8
        the buzzing is coming from the lights themselves. the dimmer itself is quiet.
        1. BillBrennen | Feb 16, 2007 02:13am | #11
          Some bulbs are quieter than others, as John mentioned. The better the filament is supported, the less it will buzz, all else being equal. The expensive Phillips R-30 lamps from HD are much quieter than the cheap Feit R-30's from the same store.Bill
        2. Hackinatit | Feb 16, 2007 02:19am | #12
          Our GE Reveal bulbs hum like flourescents on a dimmer.Troy Sprout
          Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it."-- Thomas Sowell
          IMERC | Feb 16, 2007 03:45am | #14
          cheap bulbs...
          go with a Philips R-30.........Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
    3. hasbeen | Feb 16, 2007 04:32am | #17
      Hey Marty, I have a humming/buzzing switch. It is clearly the switch, not the bulbs, that buzz. It doesn't buzz at all WHEN THEY ARE ON FULL POWER.There are six 60w bulbs on that switch. I don't understand how my problem could be overloading, but then I'm no EE.Damn. Now I'll have to do somthing about it. <G>
      "Doubt is not a pleasant condition, but certainty is absurd."
      ~ Voltaire
        IMERC | Feb 16, 2007 04:34am | #18
        get a better dimmer switch...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      2. JMadson | Feb 16, 2007 04:46am | #19
        Any chance do you have one of those newer flourescent bulbs in one of the fixtures?
        My dimmer started buzzing once I put one of these in. “The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
        1. hasbeen | Feb 16, 2007 04:52am | #21
          I'll check. Thanks for the suggestion.
          ~ Voltaire
      3. JohnSprung | Feb 16, 2007 04:48am | #20
        The buzz is worst mid-way thru the dimmer's range.  When it's on full, it just passes everything thru.  When it's off, it's off, there's nothing happening.
        The dimmer works by turning off every time the AC goes through zero volts, then waiting a while before turning on and continuing with the 60 Hz. sine wave.  How long that while is, is what you're adjusting with the knob or slider.  The electromagentism that yanks on stuff and makes it buzz is proportional to the rate of change of Voltage, so there's much more of it during the brief periods when the triac turns on and re-joins the sine wave.  The farther it is from the sine curve, the longer those jumps take, and the more magnetic energy there is.  So it's loudest and worst at 90 degrees.
        -- J.S.
        1. hasbeen | Feb 16, 2007 04:53am | #22
          Thanks for the post, even though I don't know enough to understand most of it.
          ~ Voltaire
          BillHartmann | Feb 16, 2007 05:47am | #23
          I doubt that triac or associated circuity it making the noise. But I suspect causes is that many of the units have chokes in them to reduce RFI and that choke has a loose core or loose mounting. And it is being jerked around by di/dt..
            SamT | Feb 16, 2007 08:00am | #24
            mnn,
            I thinks he said that it is the sharp voltage/current spike caused by the triac that is creating the magnetic pulse that is driving the vibrations of things like a choke or core.
            SamT
            Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either. [Einstein] Tks, BossHogg.
            Edited 2/16/2007 12:02 am by SamT
          2. JohnSprung | Feb 16, 2007 11:05pm | #26
            Yes, exactly.  The choke is the only place in the dimmer where a significant amount of energy could make the electrical to magnetic to mechanical transitions.  That and bulb filaments are the potential trouble spots.
            -- J.S.
  2. JohnSprung | Feb 16, 2007 02:09am | #10
    The main culprit is the tightly coiled filament in the bulb.  It acts like an electromagnet, and gets pulled towards the steel of the can.  Rough service bulbs don't use tight coils, so they tend to buzz a lot less.  Fixtures that put a lot of distance between the bulb and any big sheet steel parts would also help.
    -- J.S.
    1. bchanson | Feb 16, 2007 02:24am | #13
      i just have regular soft-white light bulbs in there now while we are painting and doing trim because we don't have the finish trims installed yet. i'll see if it helps with the real par 30's in there before i go switching out the dimmer. thanks everyone
    shelternerd | Feb 16, 2007 08:13am | #25
    If the client is habitually dimming the bulbs to less than 50% of their desired light output the on-off action of the dimmer can cause the filaments and the bulbs to vibrate. That Lutron dimmer is most likely rated for 600 watts total so probably not overloaded. Have your client replace the bulbs with lower wattage bulbs so the dimmer is normally not cut to less than 50% of light output and the problem will go away.
    1. JohnSprung | Feb 16, 2007 11:09pm | #27
      That'll work if they can live with the reduced maximum output.  We may have the lights dimmed quite low for much of the time, but then turn them up full for clean-up when the party's over.
      -- J.S.
      1. SBerruezo | Feb 17, 2007 04:06am | #28
        Former client asked me if I had any idea why her switch was buzzing, even when flipped off at night.  It's apparently sporatic, and occasionally wakes her up.  I had no clue, I'd never heard of a switch buzzing.  Would swapping the dimmer be the solution?
          BillHartmann | Feb 17, 2007 04:41am | #29
          If it was OFF then there should not be any buzzing with either a plain switch or a dimmer.Was it something like a X-10 switch or anyother kind of "electronic lighting control system"?My guess is that it was not the siwtch, but something else that was transfered to the studs by the switch.Maybe a bee hive in the attic..
          1. Ragnar17 | Feb 17, 2007 10:43am | #30
            Bill and others,
            I've experienced the same problems with dimmers as described here -- the buzzing is worst at low light settings and (nearly) goes away when turned up to full.
            I replaced the bulbs with the 3-way variety and the buzzing all but disappeared.
            Does that make any sense to anyone from a theoretical perspective?
            Question2: what will eventually happen to a dimmer switch if it IS overloaded?
Drafting the 2027 IRC
  • The New Old Colonial
