can light ?
migraine | Posted in General Discussion on August 25, 2006 02:39am
I need to settle a “disagreement” with my neighbor across the street .  He is a one of those ” whatcha doin?” kinda guys and is an retired eletrician.  Some Union guy from New York.  (retired well.  Has a $175k diesel motorhome)
I’m installing 6″ low profile non IC Halo canlights(#H27T) in a ceiling in the kitchen .  the 2×8 joists above are non insulated but have T&G floor above.  He says that the can must be IC rated because of the floor above, I say no way because there is no insulation.  Just air space between the joists and about 2″ from the top of the can to the bottom of the T&G.
Whose right?  Am I learn’ something new today?
  1. cap | Aug 25, 2006 03:43am | #1
    You're right, if the straight NEC is the operative Code where you are.
    But many cities have more restrictive requirements in their electrical codes, so he may be right for where he's from.  Which is not where you are.
    Cliff
    jhausch | Aug 25, 2006 05:48am | #2
    Glad to hear I am not alone.
    Retired Union Plumber next door; however, he does not limit his advice to plumbing.
    For your project, See if the mfg instuctions have clearances to stuff listed - in the absence of other info, I'd start there.
    http://jhausch.blogspot.com
    Adventures in Home Building
    An online journal covering the preparation and construction of our new home.
A Practical Perfect Wall
  • The New Old Colonial
