I’ve been drawing some floor plans in 2D using Autosketch 8. Autosketch is a simple 2D CAD program from Autodesk, kind of Autocad very very lite.
I’d like to generate some 3D renderings to see how things fit and flow. Does anyone know of any cheap (<$100) software that can import a .DWG file and then use it for 3D modeling? I’m just a homeowner DIY so I’m not looking for professional level. I’ve looked at the popular home programs like Better Homes & Gardens Home Design, which is based on Chief Architect, and Punch Home Design. They apparently don’t allow .DWG file importing so I would have to re-enter the drawings from scratch. The websites are ambiguous about file imports so if anyone out there has used them with .DWG I’d love to know.
Thanks for any help or direction.
I'm not sure if the free Intellicad is still available for download out there or if it imports DWG or not. Might be just DXF.
I'm thinking TurboCad, but most of my data on competing programs is three years old. I use Softplan
Stay away from Punch. It is widely reported to make 'corrections' without telling you.
http://www.infograph.com/products/dwgviewer/
look what I just found - free autocad viewer
Piffin, thanks for the replies. I can save .DWG files in Autosketch and I can import them too, so the viewer part is already taken care of. Autosketch saves by default in an AS file format which is not very common, but since I can take one of my drawings and save it as a .DWG I'm trying to find something relatively cheap that can take the 2D .DWG file and convert to 3D view.
I'm not a professional, you pros can look at a floorplan and see it in 3D, spot the flaws that look OK on paper but don't translate to the real world. I'm going to need software to do that for me.
Us pros have blind spots too. One of the beauties of working with 3D software is that you can review your work for errors and taste.
Check out SketchUp, download the trial, and you can import your
dwg files directly. There is a slight learning curve to the software, but if you have some time look at tutorials on youtube. If your elevations can be imported that is all you will need to create a 3D model of your project. Best of luck.
thanks John, I'd forgotten about Sketchup.
ak....
<<<Better Homes & Gardens Home Design, which is based on Chief Architect>>>>
you can pick this up pretty cheap on EbayMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
