Can concrete be used to fill in cinder block? I’ve always been told to use grout but concrete is less expensive. Any help will be greatly appreciated. Thanks.
There's a constant source of clean water for you to use, and all you have to do is collect it.
seen it done that for a very long time...
WOW!!! What a Ride!
Someone can correct me if I'm wrong, but I think "Grout" is a generic term meaning something to fill a void. Thus, grout can be concrete or any other material used in this manner.
~ Ted W ~
Cheap Tools! - MyToolbox.net
See my work - TedsCarpentry.com
Well, 'grout' as a verb when used with block means to make a solid fill. The engineering requirements of the wall define what that material is. the term is used to differentiate between the use of mortar to join the blocks and the material used for filling them.
"Grout" as a noun can refer to "non shrinking grout" which is a portland mixture which does not (appreciably) change volume after setting. That creates a transfer medium by which loads pass from one point to another. Some NSG can be used to fill block voids, but usually a structurally-specified concrete is used in combination with rebar.
I used pea gravel mix in mine. I added some water reducer, add a super P . poured it almost like water. got 8000 psi out of it
English lessons aside, when they say to fill block with grout they mean use a cement based material. Normally either mortar or concrete with a smaller aggregate.
Thanks for the help guys. Your responses are much appreciated.
Grout is usually made of the same ingredients as concrete; namely, portland cement, aggregate (sand and stone) and water. Because the mix has to run into every nook and cranny of the space and surround and tenaciously bond to steel, grout usually has to have much more slump and it often has to be made with smaller aggregate than most concrete mixes. Since tenacious bond is the main design goal, it is usually specified with a higher percentage of portland than most concrete mixes.
