circular saws – left vs. right
CCI | Posted in General Discussion on June 23, 2008 09:57am
I was using my friend’s 18v cordless circular saw yesterday and was wondering why the blade is on the left side like a worm drive not on the right like a sidewinder even though the cordless is a sidewinder.  The one in question is a ryobi but I have used a dewalt and it is also blade on the left side.
My corded bosch is on the right side as are most other corded I have used except for the worm drives.
Any reason for the switch or just trying to mess with my head?
Thanks.
  1. frammer52 | Jun 24, 2008 03:45am | #1
    me thinks they be messing wid us!
  2. MSA1 | Jun 24, 2008 04:09am | #2
    I saw an article in FHB where someone was cutting a skirt board for a staircase. They actually needed both a right and left circ saw to make the miter cuts.
    1. gordsco | Jun 24, 2008 06:03am | #8
      We used to cut open stair skirts freehand with a tablesaw, I had one that tilted right for left handed skirts and a tablesaw that tilted left for right handed skirts. "Perfect is the enemy of Good."    Morrison
        McDesign | Jun 24, 2008 06:56am | #9
        LOL!  That's a TOH jioke, even.
        "Now, Norm will take the piece over to the OTHER tablesaw and complete the cut."
    Matt | Jun 24, 2008 04:30am | #3
    Aside from the odd circumstance similar to what MSA1 described it's mostly just personal preference....  I have both.  Blade left (for a righty) means more accurate cutting based on easer view of the blade, but this also means more sawdust/whatever in my eyes.  Also, with a blade left saw (again for a righty) the fingers of your holding (left) hand can end up closter to the blade...
    1. frammer52 | Jun 24, 2008 04:37am | #4
      We use both right and left for cutting facia!  on every house.
        Matt | Jun 24, 2008 04:55am | #5
        Sounds like you cut your fascia in place...
        1. frammer52 | Jun 24, 2008 05:44am | #7
          sub-facia!  can't bevel facia when installed.
          1. ANDYSZ2 | Jun 24, 2008 10:40am | #11
            Funny ,in the last 2 weeks I have done exactly that at least 10 times.
            I cut fascia in place in remodel work and in new construction.
            I also keep 2 saws at the horses for opposite angles instead of standing on the other side or reversing my board.
            REMODELER/PUNCHOUT SPECIALIST
          2. frammer52 | Jun 24, 2008 08:02pm | #17
            I have used as many as 4 saws around my horses.  Don't like to go far when cutting for 4-6 guys.  I am left handed that cuts both ways.  I admit, with a left handed saw my cuts are a little straighter.
            dieselpig | Jun 25, 2008 03:52am | #19
             I'm the same way.  If I'm cutting some kind of funky roof like an octagon or bastard valley/hip or something I'll have my wormdrive like always.... but then I will also probably have a blade right sidewinder, a 10" worm with swing table, and maybe my 8 1/4" wormdrive or another 7 1/4 wormdrive.  Lotta saws making a lotta dust!
            Isn't it nice being able to use a saw effectively with either hand... beveled or not?  A couple of my guys get into gymnast mode when they've got to make an odd cut with 'the wrong' saw.... arms all crossed and running the saw back at themselves and chit.  Just looks painful to me.View Image
    McDesign | Jun 24, 2008 05:24am | #6
    Right blade for a righty; might as well close your eyes and guess, unless you want to curl your head around upside down in front of the saw.
    Forrest - opinionated
  5. davem | Jun 24, 2008 06:57am | #10
    what i like best about my left blade saw is that i can hold a speed square tight to the board with my left hand and use it as a guide to get a perfectly square cut with the saw in my right.
    1. DavidxDoud | Jun 24, 2008 02:22pm | #12
      I wondered about the speed square on the blade side of the saw - you do it, apparently - do you feel more at risk than having the square on the opposite side of the saw?"there's enough for everyone"
      1. CCI | Jun 24, 2008 03:32pm | #13
        I can understand the need for "left" and "right" saws for special cuts.  It just seemed to me, in my limited experience, that the cordless were typically blade on left and the corded were typically blade on right.
        I actually noticed it because I ended up with much more dust on my face (I am right handed)with the cordless saw.
        Can you buy a cordless saw with the blade on the right?  All of the ones I have used/seen are part of a kit and all have the blade on the left.
        I can see how they would be good for cutting fascia in place.  I find them useless for cutting sheet goods - the battery drains down after just a few cuts and the small diameter, thin kerf blades tend to wander more than a 7-1/4" so it takes more effort to cut a straight line.  Just my own feelings, I am sure some get used to them.
        1. JulianTracy | Jun 24, 2008 03:39pm | #14
          ....I find them useless for cutting sheet goods - the battery drains down after just a few cuts That's cause you are using a Ryobi - what'd you expect with those - they are ####.The Ryobi's are cheap, but the real difference is in the batteries and chargers. There's a reason the batteries retail at $20 each.I barely use my corded saw for anything as my cordless (Bosch 18volt) cut's through sheet goods as good as the corded.True - they are not designed for ripping 2x's, but for sheetgoods no reason for the corded.Of course - for fine work, I use the Festool with the guide.JT
      2. davem | Jun 24, 2008 03:49pm | #16
        using a square on the motor side of the saw results in the motor hitting the square or my hand. plus it's easier to align everything when it's in front of you. i place the blade on the line, then pull the square in to get the saw square. i've tried it with my right blade saw, and looking around my hand and the saw to hit the line is difficult. and cutting with the saw in my left hand is out of the question. i have no left hand dexterity at all.
      3. gordsco | Jun 25, 2008 03:09am | #18
        Resting the saw on the piece of board that is about to fall away would not seem like the best approach for accuracy."Perfect is the enemy of Good."    Morrison
          dieselpig | Jun 25, 2008 03:55am | #20
          You'd be surprised.  I can put a 45 degree bevel on a 1x8 that's as good as my slider with a worm and a speed square.  No BS.  It's like anything else... you just get used to it and it becomes second nature. View Image
          1. frammer52 | Jun 25, 2008 04:05am | #21
            shoot brian why use the speed square?  We never set up anything other than the skill saws!  You have to learn quick how to cut trim straight
             or the boys get pissed!
            dieselpig | Jun 25, 2008 04:20am | #22
            I use the speed square when I'm making a first cut on a board so I don't need to mark a line.View Image
          3. frammer52 | Jun 25, 2008 03:10pm | #27
            I find that to often when using a speed square as a guide the last 2" of the cut wanders, so I mark and cut freehand.
          4. Jer | Jun 25, 2008 05:18am | #25
            You don't frame with a speed square do ya?
          5. frammer52 | Jun 25, 2008 03:12pm | #28
            Yep, to draw cuts, I have actually gotten better than using a framing square.  It took awhile!
          6. collarandhames | Jun 26, 2008 05:56am | #36
            Is it acceptable to draw a line atleast?  I had a carp when I was an apprentice tell me I'd get in trouble if I was using a speed square as a guide,, He told me that the framers only make a mark and cut at 90.  I like to draw a line and cut,, unless it's 2x8,, then I do sometimes grab the speed square.  Keep in mind I do renos,,and timberframing,, so don't get a whole lot of time to get proficient at any one task!
            dave
          7. DavidxDoud | Jun 26, 2008 06:01am | #37
            "I had a carp when I was an apprentice tell me I'd get in trouble if I was using a speed square as a guide"what kind of trouble? - 'real men' don't use a speed square? - or using a speed square with a left blade puts you in physical danger? - dunno - just asking - "there's enough for everyone"
          8. collarandhames | Jun 26, 2008 06:05am | #38
            Real men just make a 1/8" mark and cut!  I will keep marking my line and following it!
            I really like the timberframing meathod,, mark with a knife the cut,, all the way around.  Then darken the cut side with a sharp pencil.  Then a lumber crayon so you know which side you're on for sure.  With the knife line,, if you're getting tear out, you're too far!  I love timberframing!
            d
          9. DavidxDoud | Jun 26, 2008 06:14am | #39
            like you, I do a lot of different operations, rather than repetition that would build the skill for that single operation to the point of elimination of a tool - and there's framing, and there is trim - there's a reason it's called 'rough' framing - I've disassembled a number of 19th century timber frames - they were generally well done, but most far from 'perfect' - some approached elegant - I've reassembled some, with modifications - my technique was inferior to the original, tho my last ones were quite presentable - do whatever it takes to achieve the quality that is necessary - some places 'rough' is good enough - my 2 cents -
            D"there's enough for everyone"
          10. collarandhames | Jun 26, 2008 06:25am | #40
            Sometimes it's a good lesson on what will do, to see what has done!  Like porches that stand with no apparent support. OR load bearing walls sitting between floor joists, (that job had bowling alley gutters in the hall,, fun to fix ,, lots of cracked plaster)
            Anyway,, the thread is left vs right.  I've got a sidewinder,, but am thinking of a nice new 8 1/4 worm.  Be nice to have a second tilt,, and I'm getting querys of spayed stairs,, and don't want to keep borrowing worm drives.
          11. DavidxDoud | Jun 26, 2008 06:44am | #41
            I've got a 8 1/4" sidewinder, right blade - it's an anchor - I got it because, like you, I was doing jobs with full 2" material, 8X8" beams, and larger - nice to have the capacity - but it is an anchor working with common materials - so, you need a saw, get it - maybe you ought to get two....I'm trying to talk myself into that very thing right now - "there's enough for everyone"
          12. collarandhames | Jun 26, 2008 06:53am | #42
            I'm pondering a new sidewinder as well.  The depth guage on my ridgid is shot, and try as I may, I can't fix it!
            Tools that work = happiness.  Good tools that work = more happiness.
          13. Jer | Jun 26, 2008 01:34pm | #43
            "Is it acceptable to draw a line atleast?"Whatever gets the job done the best way you can. A lot of the time I mark with the tape and then just use the spped square as a guide. In fact that's mostly the way I do it.
          14. gordsco | Jun 25, 2008 04:57am | #23
            You're right, It's the getting used to it thats throwing me off.
            After 30 years of right hand saws, (although I did use a worm in the 70's), this 18v Milwaukee I got feels unnatural.
          15. User avater
            dieselpig | Jun 25, 2008 05:02am | #24
            LOL... all that being said... there are a few saws that I just could never get used to at all.  A couple of my guys love the Dewalt SawCats....to me it feels like I'm dragging the saw through the cut backwards with a brick tied to it.  But they love them.  Truly, to each his own when it comes to circ saws.
            I was just pointing out that 'it can be done' earlier when you mentioned getting a decent cut with the majority of the saw table on the 'drop' side of the blade.
            Edited 6/24/2008 10:04 pm ET by dieselpig
          16. Jer | Jun 25, 2008 05:20am | #26
            DeWalt makes a Sawcat? Used to be B&D did and then stopped. I had one from 25 years ago but it finally gave up the ghost. Best circular saw I think I ever owned.
          17. sisyphus | Jun 26, 2008 03:36am | #31
            I always liked the Super Sawcats. I still have two, one with very low hours that works and one mid 70's model for parts (and nostalgia). I hope it will last me forever given that now we use SCMs and portable tablesaws etc. for most of the cutting.
          18. User avater
            dieselpig | Jun 26, 2008 04:06am | #32
            Jer,
            I'm not sure that it's 'identical' to the original B&D Sawcat but it's pretty darn close if it isn't.  DW364:
            View ImageView Image
          19. Henley | Jun 25, 2008 03:22pm | #29
            Didn't you mention you have a hypoid saw a while ago?
            How do you like it?
          20. Jer | Jun 26, 2008 12:28am | #30
            Yeah, I do the same when I'm framing. A lot of framers just go ahead and eyeball the square cut and they're quite good at it. I do it, and some days I'm better at it than others.
          21. User avater
            dieselpig | Jun 26, 2008 04:12am | #33
            I use a couple different hypoids Henley.  I've been using the Dewalt 'framing saw' for a few years now.  A few months ago I started using the new Makita hypoid and I like it very much.  The shape is that of a true wormdrive (unlike the hybrid Dewalt style) but it weighs about the same as a sidewinder.
            Slick saw.  52 degree bevel capacity, rafter hook, great table, guard doesn't hang up,  big rubber coated levers for bevel and depth adjustment, and a very comfy handle.  Cuts super nice too.  I really like it with a nice Diablo blade.  Factory blade was truly horrible.
          22. Jer | Jun 26, 2008 05:37am | #35
            "I've been using the Dewalt 'framing saw' "After using somebody elses Skill worm drive many years ago I swore that I would get one, but never did. I just always used sidewinders I guess...but I do like the worm. I came this close to getting that Dewalt framing saw of which you speak, but they were out of them and I just settled for one of their side winders which I still use on a daily.I hear the Ridgid worm is really good. They're a lot lighter now than they were 22 years ago when I used it.The thing about the Super Sawcat was its ergonomics. It was just right, & perfectly balanced like a Samurai sword.
          23. Henley | Jun 26, 2008 03:42pm | #44
            Yeah that was the saw I've been looking at.
            It just looks comfortable to me and a whole lot
            lighter then my old Skill worm.
            Thanks it's just nice to get actual feed back before
            buying.
    Ted W. | Jun 24, 2008 03:41pm | #15
    It's odd, but every cordless circular saw I've seen has the blade on the left. I just always figured the cordless saw designers are smarter. <g>
    I both left and a right Porter Cable saws (corded) but the right side bladed one sit's idle most of the time.
    Cheap Tools at MyToolbox.net
    See some of my work at TedsCarpentry.com
  7. segundo | Jun 26, 2008 04:46am | #34
    Yes there is a very good reason.
    The reason is that it is better to have the blade on the left. Anybody who likes the blade on the right is seriously messed up.
    1. CCI | Jun 26, 2008 04:24pm | #45
      I agree that the blade on the left is easier to see and therefore safer.  That being the case, why do so many new sidewinders have the blade on the right (or wrong) side?  For example, I have a fairly new Bosch CS20, which I understand was a "clean sheet of paper" design not just an update of a previous model.  I has the blade on the right but it also has a large "cutaway" area to allow easier viewing of the blade.  It seems like just putting the blade on the left side eliminates those "bandaids" to make the tool work better.
      I actually design industrial equipment so it bothers me when a simple solution is ignored and you have to engineer work arounds to solve the design flaws.  Unless I am missing something else, I can't see the reason for the blade on the right unless the designers were all left handed.
      1. DavidxDoud | Jun 26, 2008 04:42pm | #46
        one thought I've had during this thread is that there seems to be a lot of people trying to watch the point where the blade meets the wood - I believe that to be generally wrong - you should be watching the index on the shoe to see where you are going, not the blade to see where you are at - if you watch the blade, by the time you observe the cut going off the line (you're splitting the line, right?) the inaccuracy is chiseled in wood - "there's enough for everyone"
      2. segundo | Jun 26, 2008 04:50pm | #47
        traditionally blade on right is east coast, blade on left is west coast.
        construction in many aspects is slow to change. metrics vs. feet and inches fer cryin out loud, how much easier is it to multiply everything by ten?
        some guys still like blade right, its what they are used to and have developed skill with. they don't want to have to relearn to do it a different way when its already commited to muscle memory.
