I am in the process of renovating a 1910 home (plaster walls with
balloon framing) and am planning on making a small room (approx.
8’x12′) into a study with built in bookcases and a coffered
ceiling. I pulled down the previous ceiling (two layers of
acoustical ceiling tile fastened to strapping which hid badly
damaged plaster; what a mess!) and the floor joists for the
second floor are now exposed.
I have found very little on coffered ceiling construction and
wonder if anyone has any suggestions on where to look or even
how to do it? A back issue of FHB had a nice article on doing
this, but the method involved required access to the wall studs,
and I’d rather not pull down the plaster on the walls in order
to do this. I also saw a kit for a suspended coffered ceiling
system (www.woodgrid.com); looks like an interesting solution but
might be more then I want to spend.
TIA,
Ron
Gary Katz has a book out that has a simple method that works well.
Thanks for the suggestion Paul. Do you happen to know the title of the book
by Gary Katz? I seem to be having trouble doing a search on the books available
through Tauton Press on there website.
Ron
JLC/Craftsman Books published it. It is available from Amazon
http://www.amazon.com/exec/obidos/ASIN/192858005X/qid=1017764663/sr=1-1/ref=sr_1_1/103-9188668-2578227
Actually if you are not in hurry I would wait a month or so. It quality of the pictures is not that good and they are print a new edition now.
Thanks for the info Bill.
Ron
Ron,
Let's hope so. . .
I'm with Joe on this one.
A skin of ply works wonders with coffered ceilings, or when tinning them.
After skinning w ply, screw nailers to the ply, then fasten your "U" faux beams (or whatever you choose to do) to the nailers.
Joe, you've got to lend me that plywood stretcher of your someday.<g>
Edited 4/2/2002 12:11:39 AM ET by Mongo
Mnogo -
Maybe Joe buys bigger sheets of plywood than we do..............(-:
Mongo, Boss,
They say lightning dosen't strike twice. . .
Let's hope so. . .
I never would have thought of using plywood. I still have some firring strips
fastened to the floor joists that the old plaster lath was attached to; would you
suggest I fasten the plywood to them or pull them down and fasten it straight
to the joists?
Although I'm curious to see what Gary Katz has to say in his book, I'm thinking
about making faux beams out of hardwood (screwing it to the plywood), and
then use crown moulding to dress up the inside of the boxes. I'm wondering if
I could get away with using some kind of veneer plywood and then stain that
so the coffer would all be stained wood?
Ron
Ron,
Let's hope so. . .
Joe,
Do you ever have any problem with the two bys trying to twist and roll on that detail? It looks practicle and do-able but the framing lumber we get doesn't like to hold still.
I'm supposing that the smaller sections created in a coffered ceiling would let you cross lap joints to tie them together and resist that effect.....
Piffin,
Let's hope so. . .
I never buy green. KD only but KD is dried to 19% surface is all. For wood work 11% or less is about right for my area. I'm in the habit of buying an extra fifteen percent for framing and try to use up the junk on blocking, braces, etc.
This past year I went back into a basement room to finish it after letting it set for a year because the owner delayed the job after we had the interior framed. Had to replace and renail lots of studs because of twisting.
Common lumber here is spruce which has more of a natural tendency to twisting than doug fir, hemlock or SYP.
I wasn't challenging your choice of wood but trying to see if you did anything to overcome the natural tendencies like using construction adhesive or screws instead of nails.
That's exactly what I'm looking for J; thanks alot!
Will be starting on this in a couple weeks and will
let you know how I make out.
Ron
Ron,
Let's hope so. . .
Joe,
Any advice as to proportions in the ceiling? Such as, square size of the flat area and also its relationship to the "frame" widths. I'm trying to visualize if a coffered ceiling inset into 16"oc joists would be visually appealing or not. I'd build molding on each side of the joist bottoms, etc with drywall panels. Insetting would gain visual headroom in a low ceiling. Opinions?
Thanks,
Steve
Steve,
Let's hope so. . .
Steve,
Let's hope so. . .
Thanks for your thoughts Joe.
Ya, the < 14" area for the flat part is probably too small a grid. I was hopeful that maybe you'd seen it done with such a small grid and thought is looked ok. I'll have to come up with something else to dress up the ceiling while gaining a bit of altitude inside the joist bays. I don't think my wife liked the idea anyway.
Steve
