concrete block leeching
muffy | Posted in General Discussion on April 20, 2005 06:12am
The walls in our 5 year old contemporary home are concrete block (CMU) and exposed on the interior. The “look” is natural so we sealed them both inside and out with “Lifetime”, a silicone product. We resprayed the outside again 3 years ago.
We now have white powder on the inside of the walls, mostly in the grout area. This not only looks bad but continues to appear and partially fall off the walls. No matter how much I brush and vaccuum the walls it keeps making a mess.
Is there a clear product that we can apply to the exterior to prevent further leeching? Is there a way to remove this white stuff from the interior of the walls?
    IMERC | Apr 20, 2005 06:29pm | #1
    welcome Muffy...
    sounds like lime leaching..
    what part of the world are you in and what kind of climate do you have...
    not famoliar with "Lifetime"...
    WOW!!!   What a Ride!
    Forget the primal scream,  just ROAR!!!
    1. muffy | Apr 20, 2005 06:41pm | #2
      I live in the Monterey area of California....sometimes cold and rainy, sometimes dry and hot. Seems to happen all of the time.
        IMERC | Apr 20, 2005 06:54pm | #3
        I use to live there...
        who makes "Lifetime"
        WOW!!!   What a Ride!
        1. muffy | Apr 20, 2005 07:53pm | #5
          Lifetime is made by Mulford in California. It's rubber and silicone and is called a waterproof sealant.
          The blocks are filled with lots of rebar and cement.
          We called the manufacturer years ago and I don't remember their response, but, obviously their product doesn't work as advertised.
          I'm just wondering if there is another product out there that does work and is clear. Also how do I get the stuff off of the walls on the interior.
          Thanks, whoever you are....
          1. DANL | Apr 20, 2005 09:09pm | #6
            It might be efflorescence--basically caused by water getting in and it leeches minerals to the surface and evaporation leaves a crust of mineral salts. If you keep the water out, this shouldn't happen. If brushing it off works, keep doing that, but treat the outside with something better to keep the water out. What are the block walls resting on?--water may be coming up through the ground and wicking into the block.
            I believe, but am not absolutely sure, that a fairly weak solution of muriatic (hydrochloric) acid will remove efflorescence. Perhaps even white vinegar would work.
            Edited 4/20/2005 2:12 pm ET by Danno
        IMERC | Apr 20, 2005 06:55pm | #4
        BTW.. are the block cells filled...
        WOW!!!   What a Ride!
A Practical Perfect Wall
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
