Concrete Footing Good News/Bad News
JohnSprung | Posted in General Discussion on July 11, 2002 10:00am
I got the compression test report back on that little footing – 6390 psi, pretty good for home brew mud, right?  But the bad news is that it looks like the rebar assembly did sink a little bit after I cut it loose from the overhead supports, and it looks like I got kinda generous on screeding.  Bottom line, the J-bolts don’t stick up quite as far as they should, only about half way into the nuts.  I’ll probably try cutting some kerfs with a diamond saw and then breaking out between them with the Bosch hammer, unless anybody has a better idea.
— J.S.
  1. AlanRoberson | Jul 11, 2002 10:35pm | #1
    If code allows, hammerdrill new holes & install new bolts?
    1. MisterT | Jul 12, 2002 12:10am | #2
      Tapcons sound like the plan here.
      If codes allow
      TDo not try this at home!
      I am a trained professional!
  2. RalphWicklund | Jul 12, 2002 04:23am | #3
    What footing? Did you intend to post a picture? What are you holding down with these J-bolts?
    You can stretch those bolts to get the thread you need but first you have to cut off some. Use a Simpson CNW coupler nut threaded onto the J-bolt after you cut off just enough to leave thread to seat to the stop in the nut. Add a short length of All-thread and then the washer and nut. You will most likely have to oversize the hole in the bottom plate to accept the coupler. If the combination is too tall you can add a few of the larger washers and if still way too tall you may have to double up the bottom plate at that location.
    Sometimes, but not often, the J-bolt will have a lot of thread, buried in the footer. A little chipper action and you can expose the threads. Cut the bolt flush with the footer and thread the coupler. It will now stick up only a little.
    1. JohnSprung | Jul 12, 2002 10:21pm | #4
      It's the one I have in the photo gallery under "New footing in the middle of  the house"  I'll post more pictures later.  The last ones were from before the pour.
      A cripple wall ten inches high under an existing 4x6 girder.
      > Use a Simpson CNW coupler nut ....
      Ah, yes, thanks.  I like that idea much better than tapcons.  There's a place nearby that should have them, they specialize in anything to do with concrete work and earthquake retrofitting.
      -- J.S.
      1. FastEddie1 | Jul 13, 2002 06:11am | #5
        I went and checked the pics, and not to be critical, but it looks like you were a little skimpy on the amount of exposed thread before th pour.  In hindsight it would have been a lot easier to leave anouther inch of thread exposed and cut it off later.
        1. JohnSprung | Jul 16, 2002 03:05am | #6
          > it looks like you were a little skimpy on the amount of exposed thread before th pour.  In hindsight it would have been a lot easier to leave anouther inch of thread exposed ....
          Yup.  I really f-ed up on the j-bolts.  I spent about 2 extra hours with the diamond saw and Bosch hammer getting the 3/16" I needed.  There's a picture of the results in the photos now.  The bottom of the groove is kinda bumpy, so to distribute the load properly I think it might be good to even it out with a bonding agent and a very thin layer of concrete.  I'd wrap the sill in plastic and use it to form the new surface.  What do you think?
          Thanks --
          -- J.S.
          1. FastEddie1 | Jul 16, 2002 05:53am | #7
            Can you run the nut down snug, then squirt epoxy or grount under the wood?
            Just went and looked at the pic (you're getting better with the Kodak!).  What about laying down a bed of slow setting epoxy first.
            Edited 7/15/2002 11:03:49 PM ET by ELCID72
Reduce Embodied Carbon With Simple Forms
In addition to adding cost to a project, a complicated design is responsible for increased embodied carbon emissions.
  • Monitor Both Outdoor and Indoor Air Quality
  • What You Need to Know About Installing Steel Siding
  • Podcast 570: PRO TALK With Project Manager Jeremy Hess, Part 1
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
