Concrete Forms
Cassieman | Posted in General Discussion on February 22, 2006 06:01am
Does anyone out there know of a LVL manufacturer making dimension lumber treated for use in contact with concrete.  I’m getting ready to build window and door bucks for use in a styrofoam form walkout basement. Pressure treated lumber has a tendency to turn into pretzels at this altitude and our building inspector will not allow using a moisture barrier on standard LVL. Would really appreciate any help with this.
  1. Notchman | Feb 22, 2006 06:45am | #1
    Arxx and some of the other ICF manufacturers offer PVC window and door buck material which, after the pour, give the isolation from the concrete for whatever R/O material you prefer.
    They're a channel profile and plenty sturdy....with today's PT with all its pitfalls, the PVC buck material is probably a good alternative.
  2. Catskinner | Feb 22, 2006 07:05am | #2
    Might not hurt to talk with your inspector about this. There is no code provision for his decision -- the prohibition is against direct contact.
    If you were to flash the LVL with a 60 mil bituthane membrane there would be no rational reason to prohibit this. If your inspector needs belt-and-suspenders, you could go with 60-mil adhesive membrane (like Mira-Dri Grace) and sheet metal.
    Power always thinks it has a great soul and vast views beyond the
    comprehension of the weak; and that it is doing God's service when it is
    violating all his laws. -John Adams, 2nd US president (1735-1826)
  3. Brian | Feb 23, 2006 03:13am | #3
    Why use an LVL?  We used dimensional lumber wrapped in felt paper for window bucks.  The VBuck vinyl product was crazy expensive.
    BTW - whats your altitude?  PT twists pretty well here near sea level too!
    Treat every person you meet like you will know them the rest of your life - you just might!
    Edited 2/22/2006 7:14 pm ET by Brian
  4. kcoyner | Feb 23, 2006 04:54am | #4
    Here's one.  http://www.trusjoist.com/PDFFiles/2111.pdf  I haven't used the treated products but use the standard products all the time.  Good products, good design help, good support.
    k
