Consequence of not-to-code
Gene_Davis | Posted in General Discussion on May 18, 2009 02:14am
You want to sell your house.
Let’s presume that the same code is in effect now as regards this, as was in effect at the time the place got built.  Let’s say that build happened ten years ago, just for info.
A lot of the windows in the house, were supposed to be glazed with tempered glass.  No ambiguities here, it’s real clear.
The buyer, being prudent about the offer and the contract, has hired a professional house inspector, and the inspector sees no temper blazes on the lites.  She asks you about this, your response is unsatisfactory in that you cannot prove the windows have tempered glass, and she points out the fault in the inspection report.
What are you going to do?
Ever heard of this happening?
“A stripe is just as real as a dadgummed flower.”
Gene Davis        1920-1985
  1. MikeSmith | May 18, 2009 02:25am | #1
    well, you're the window expert....so you know the answer.... why don't you enlighten us zen-master ?
    1. rez | May 18, 2009 07:20pm | #22
      Congratulations!
      MikeSmith receives the TimMooney 'Now That's Funny Right There' Award.
      Saaalute!View Image
    BillHartmann | May 18, 2009 02:25am | #2
    It really doesn't matter what the code is or was at the time.
    And a lot of time it might not be easy to determine exactly what code requirements where, if any at the time. And also for an older home when the work was done.
    The inspector can report that the location does not have safety glass and current practice is to have it in that application. And they that buyer to be aware of the safety issue.
    That is done all the time, for example lack of GFCI's is 50 yo homes.
    Then it is up to the buyer and seller to see how signficant that this issues is, how much it would cost to fix, and if either side wants to pay for it or if this is a deal breaker.
    Probably a better example. Say a say a high deck with just a top rail and one about 1/2 way down. The inspector would probably call this out.
    Then the buyer might say that hey were are older and don't have kids/grand kids and don't have drunken parties so we are not going to worry about this and look at other things.
    Another might have 5 kids from 1 to 6 and feel that this is an important issue. And the seller might find that the way that the deck made, the size, and the height that it might cost $10,000 to fix right and say that they will wait for a childless buyer.
    1. DanH | May 18, 2009 06:22am | #13
      Of course, a big part of this is a (all too common) scam. A price is agreed, "pending inspection". The inspector finds stuff that, if one were honest, is "normal wear and tear"/to be expected in a house of that vintage. The would-be purchaser then uses this to arm-twist a price reduction.
  3. Grampie | May 18, 2009 02:30am | #3
    I have had similar situations for some of my customers. You can reject the inspectors comment based on the fact that the windows were never replaced and were to code when the structure was built. If you were to take any other position, what would you say of a 100 year old house?
    the worse case is a realtor from hell who knows it all.
  4. davidmeiland | May 18, 2009 03:08am | #4
    It doesn't matter until the buyer or the lender says something. I inspect houses sometimes for potential buyers and point out all sorts of problems. In a seller's market they go uncorrected, in a buyer's market the buyer may counter by saying that the windows need to be tempered before the inspection contingency is removed. The seller can then solicit prices for replacing the windows and decide whether or not they want to do it. They may counter that they will credit the buyer $X to deal with the windows after closing.
    A couple of weeks ago I inspected a building with a couple of significant problems, and the buyer is using the info to get the seller to lower the price.
    1. fingersandtoes | May 18, 2009 03:23am | #7
      I wonder how may of the projects we have all built meet current codes? I know only a couple of mine have even a remote chance since they brought in rainscreen requirements.
      1. sledgehammer | May 18, 2009 03:40am | #9
        I have made many doors and windows with tempered glass that had no logo's per the clients request.
        I know how they got it approved and it's ashame you don't.
  5. danusan10 | May 18, 2009 03:09am | #5
    Take a BFH and bust the window see what the glass does, if it shatters in shards its not tempered.  Okay now bust everyone in question just to be sure.
  6. Dave45 | May 18, 2009 03:20am | #6
    You seem to be asking if an inspector can call a code compliance issue based on a ??? year old code. I suppose that they can, but for it to truely be a code compliance issue, he would need to show that it actually violated code back then. Otherwise, he's just pointing out that it doesn't meet current code.
    I do quite a bit of "fix-it" stuff for realtors based on property inspections and often have to 'splain that a 50's era house didn't require grounded plugs, or GFCI's.
  7. ponytl | May 18, 2009 03:39am | #8
    man the real fix is.... get some of that spray on etched glass frosting stuff... make a little stencil and spray you a little sign thing in the corner of each one...  won't mean a thing but i bet...
    no one would look close enough to know that you just happen to like the look of small frosted areas in the corner of your windows...
    p
    1. john7g | May 18, 2009 03:58am | #10
      mkae th stencil say "ponytail says thy're etched glass" and I bet no one ever reads it.
      PeteDraganic | May 18, 2009 04:01pm | #20
      That is absolutely hilarious. That's why you are the man.
      I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
      Take life as a test and shoot for a better score each day.          Matt Garcia
  8. atrident | May 18, 2009 05:35am | #11
    I think you can use some 3M burgler proof stick on that will meet breakage requirements. Its not cheap,but hey, safe and burgler proof. Oops , I mean Burgler resistant.
  9. semar | May 18, 2009 06:15am | #12
    A home inspector's report is just that - a report
    If the homeowner insists on the latest code requirement he should buy a brandnew home from a developer
    The market -- seller's or buyer's - often decides the deal. It comes down to compromises in any case.
  10. User avater
    Nuke | May 18, 2009 02:24pm | #14
    Gene, which is worse in the eyes of your county: Not being up to code, or not being permitted in the first place.
    I think my state would be more concerned with the codes, but I know my county only cares about missed tax assessments where they didn't get the opportunity to bend you over.
    BTW, I've done everything to code (actually, in excess of it in cases where I could), but did not permit it. I see no sense in paying the county, and its over-valuation system, an extra +$1,200 per year. Not in this economy.
    1. dude | May 18, 2009 02:42pm | #15
      The inspection is a way for the agent to cover the brokers #### in case a buyer wants to come back on them for ommissions on the home discription
      By the same token the buyer still thinks he can sue the inspector for any omissions on his report
      Been in court on one of those which took 2 days and home owner lost and he was stuped enough to produce a home inspection report that the home insperctor did not do inspections on ground source furnaces but home owner felt previous owner had misled him ( she came up from georgia to ontario to defend herself )
      Home inspections are just one persons viewpoint as to the condition of a property
      buyers often think anything pointed out will be corrected at the venders expense , and where they get that idea from i dont know  other than some buyers think their the world's greatest hagglers !
      jonblakemore | May 18, 2009 07:28pm | #23
      To be a devil's advocate, how is shirking your portion of the tax burden any different from the welfare queens who know just how to scam the system with fake social security numbers or the billionaire investor who finds an illegal but effective way to hide assets?
        Nuke | May 18, 2009 11:55pm | #26
        I do not see a difference. And I am not advocating what they do wrong either.
  11. Henley | May 18, 2009 02:49pm | #16
    I can't imagine any of the inspectors around here
    catching that!
    They are usually recommended by the Realtor and wouldn't want to
    blow a sale over a silly safety issue.
    1. mikeroop | May 18, 2009 03:19pm | #17
      Just for those who don't know, Gene lives in the WHAT IF world. never really any real reason for his questions just lets say!
        Gene_Davis | May 18, 2009 03:31pm | #18
        I sold a spec house in '06, to a buyer that was very hardnosed.  The inspector she hired was totally up on the building code and tempered glass.  I had done tempered glass everywhere the code required, and he carefully noted all the temper blazes.
        I am certain, because of the way things went down with that sale, that I would have had a big problem had glass not been tempered.  The house happened to have been new.
        We don't get inspected here by the AHJ, nor does the AHJ check plans to any degree.  All they look at is building size and height, size so they can charge as much as possible for the permit, and height so that they won't OK a house too tall.  They don't want to be involved in any lawsuits about height, which is a touchy thing here.
        I am doing the plans now for a client who will self-build, and the project is full of glass which should be tempered.  My drawings will call out the windows, where required, as requiring tempered glass, and I know he will buy them without, so as to save money.
        So, yeah, it's a what-if Q, but it's not just a hypothetical one.
        "A stripe is just as real as a dadgummed flower."
          BillHartmann | May 18, 2009 03:34pm | #19
          You say that there is no inspections. But is there a building code that has been officially adopted by the city, county, or state legislation that covers your area?If not there is no "code"..
          1. frammer52 | May 18, 2009 05:40pm | #21
            But is there a building code that has been officially adopted by the city, county, or state legislation that covers your area>>>>>>>>>>>..
            We have a state code that is supposed to cover all of NY.  In practise where he lives and in some yowns where I live, the BI are parttime at best and don't know what they are doing.
            It can be a crapshoot in parts of NY.
        2. FastEddie | May 18, 2009 07:32pm | #24
          Actually, it needs to be safety glass, which could be achieved by laminated glass, and sometimes by the application of a surface film."Put your creed in your deed."   Emerson
  12. migraine | May 18, 2009 07:48pm | #25
    the buyer beware....
    no, not really
    I've worked on things the don't meet current codes.  but they were at one time.  Doesn't mean that I'm going to change everything I do to current code.
    But, I will disclose everything that I'm aware of in escrow.  Been there, done that.
    If the building department nails me for building without a permit, I'll pull the required permit and bring up what ever they require to the current codes.  Been there done that, too, as in a 1975 sqft shop.
    As for you door w/o bugs on the glass, I've recently replaced a broken pane w/o tempered.  All of the other 9 weren't, why would I spend the money?(really just time and hassle) on just one of the panes?
    As for reason of why not pulling permits,  That is another issue that usually deals with gov't B.S. and additional taxes levied on the home for the rest of our ownership.
    As for the home inspector, that "can" be a joke in itself.  I'm not trying to change this thread by that statement.  It's just I've see too many reports that were not even close to disclosing all deficiencies
    Edited 5/18/2009 12:53 pm by migraine
A New Approach to Foundations
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
