Crown measuring
dreuxgrad62 | Posted in Construction Techniques on May 19, 2009 03:32am
Need some advice from someone way more experienced than I.
Have a gable rake  and fascia that needs crown.  Having done only horizontal crown
installs, the cutting and install would hard enough due to different planes for me.
I have procured a smaller size for the fascia, which I understand will require
a slightly different spring angle.  How is the measurement done, oh, did I not
mentioned that the bottom of cove/ogee will need to be clipped because of the
 entablature; thus not being able to use the short side of the miter of the rake piece?
Build a mock-up?
Test pieces?
Thanks, Ed
  1. Piffin | May 19, 2009 06:39pm | #1
    trial and error and a rasp
    jonblakemore | May 19, 2009 06:48pm | #2
    What's the roof pitch, crown profiles width, and spring angle?
    Jon Blakemore
  3. JoeBartok | May 20, 2009 11:17pm | #3
    You have to look at the angle of the crown with respect to the plane you are working from, not the "spring angle" measured from plumb. This way, the geometry and math is recast in a form equivalent to that for a Hip-Valley roof.
    We had some good threads about this at JLC Forums ...
    Development of Crown Molding Angles
    Polygon Rafter Tables
    Here's my take on the math ...
    Compound Rake or Prow Roof Crown Molding Angles
    On a more practical note Sim Ayers ("sbebuilders") tried applying the math. Follow the links in these pages ...
    Octagon Roof Framing and Crown Molding Angles Development
    Joe Bartok
