Culture Stone over drywall
| Posted in General Discussion on August 18, 2000 04:56am
I’m looking at putting cultured stone around a gas fireplace. I read on the culture stone page that you could put the stone veneer over dry wall? The installation instructions suggest using a adhesive called formula I?
Has anybody done this? Suggestion? Tips? Will it hold?
Thanks Brent
  1. Guest_ | Aug 15, 2000 04:48pm | #1
    Brent, if the instructions say you can, then it should work fine. Durock cement board would probably be a better choice in my opinion.
    1. Guest_ | Aug 15, 2000 05:08pm | #2
      *My choice would be cement board as well,Gabe
      1. Guest_ | Aug 15, 2000 06:55pm | #3
        *Even given the manufacturer's instrucdtion, I'd be nervous as hell doing this. I'd go with w/ hardi-backer, or durock for fear of callback, and having to repair.
  2. brent_collins | Aug 15, 2000 09:07pm | #4
    Thanks for your opinions. I will do it right the first time and rip the drywall off and put durock in.
  3. Guest_ | Aug 15, 2000 09:29pm | #5
    Brent-
    Check out http://www.hardibacker.com
    Look into if this would be possible to install over the existing drywall. This would save you some time, and cleanup.
    1. Guest_ | Aug 15, 2000 11:06pm | #6
      *Definitely install over existing drywall if you can. I think the rough cement surface of Durock may be a better substrate than the smooth Hardibacker board if a mortar is used for installation. Especially on the vertical.IMHO, jiml
      1. Guest_ | Aug 16, 2000 02:27am | #7
        *Last job I was on the carpenters installed plywood sheathing and then the subtrade installing the cultured stone put tar paper, metal lath, scratch coat and then cultured stone.
  4. Jim_K_ | Aug 16, 2000 03:46am | #8
    Even w/ cement board, the instructions call for expanded metal lathe attached w/ nails that go into the framing at least an inch. Having installed some on block, I cannot imagine drywall supporting the weight of the stone or handling the mortar well.
    1. brent_collins | Aug 16, 2000 05:11pm | #9
      *I would like the durock would work as the scrath coat and you wouldn't need metal lathe. One way or another I have to rip off the drywall. The build up will put me to far out over the fireplace.Thanks Brent
  5. brent_collins | Aug 18, 2000 04:56pm | #10
    I'm looking at putting cultured stone around a gas fireplace. I read on the culture stone page that you could put the stone veneer over dry wall? The installation instructions suggest using a adhesive called formula I?
    Thanks Brent
  6. Guest_ | Aug 18, 2000 04:56pm | #11
    Each manufacturer has its own installation guidlines and instructions. The brand I use out of Napa, CA suggestes/requires that it be installed over a mortar (type S) and expanded lathe base.
    I like to follow instructions.
Drafting the 2027 IRC
  • The New Old Colonial
