Hey,
I am using bx for a wiring job. Is there a tool you can use (except a hand saw) that can cut this stuff without damaging the wiring inside?
Hey,
A standardized approach, quick-to-install hardware, and a simplified design make building custom casework cost-effective.
Sure is...looks like an old fashioned crank can opener skinnied down...slip the bx in, turn the crank a few times (has a small saw blade attached), and it cuts through cleanly. All electrical supply houses have them, and I saw on in Lowes in the electrical dept. Is bx legal for where & what you're doing? Not all cities have embraced it.
Do it right, or do it twice.
Edited 6/3/2003 12:02:15 AM ET by ELCID72
Called a roto split.
http://www.contractorstools.com/seatarmored.html
