Cutting Scribe Lines
JourneymanCarpenterT | Posted in Construction Techniques on June 1, 2008 04:52am
What is your method of cutting and fine tuning scribe lines, and why do you prefer doing it that way?<!—-><!—-> <!—->
Example:<!—-> <!—->
When cutting baseboard scribe lines, do you use a handsaw to cut close to the line, and a low-angle block plane to fine tune it?  Why do you prefer doing it that way?<!—-><!—->
–T
    McDesign | Jun 01, 2008 04:55am | #1
    I rub it on various parts of my rusty ol' truck.
    1. Piffin | Jun 01, 2008 11:31pm | #24
      I rub it on various parts of my trusty old puck.Seriously, I usually hit it with my hand held power plane
    2. m2akita | Jun 01, 2008 11:46pm | #27
      Man, I didnt know that my pickup is actually a scrib'n truck.  Its got enough rust for an entire subdivision of scrib'n.
       Live by the sword, die by the sword....choose your sword wisely.
    3. hvtrimguy | Jun 02, 2008 12:48am | #31
      LOL - twice"it aint the work I mind,
      It's the feeling of falling further behind."Bozini Latinihttp://www.ingrainedwoodworking.com
  2. MSA1 | Jun 01, 2008 05:22am | #2
    Recently been introduced to the belt sander. Last scribe I did was a cabinet filler. I freehanded it on the tablesaw and finished up with the belt sander.
    Worked great.
  3. DougU | Jun 01, 2008 06:15am | #3
    -T
    You saw my videos on the right angle grinder? same thing for scribes.
    If the scribe needs a lot removed I will use the circular saw on it first (blade tilted for a good back cut) then clean up with either a block plane or right angle grinder.
    If scribing something to stone or very irregular area its pretty much all grinder, counter tops - skip the belt sander and go directly to the grinder.
    Dinosaur | Jun 01, 2008 06:19am | #4
    Jigsaw, then belt sander.
    If it's really critical, or if the material's really expensive, I'll cut a plywood or OSB pattern first, tune it by hand, then do the finish piece with a flush-cutting router bit following the pattern.
    Dinosaur
    foolish men call Justice....
    1. lwj2 | Jun 02, 2008 02:56pm | #50
      Minor hi-jack here, Dino --What make jigsaw do you use? I've got a DeWalt and the blade wanders now and then, usually at the start of a cut.I expect the problem lies in the hand on the saw, but was wondering.Oh -- Kid's back from Iraq. Bhog be thanked. No casualties for his unit on that deployment.Leon
        Dinosaur | Jun 02, 2008 09:24pm | #51
        Hallelullia on that homecoming, Leon. Good news to hear.
        I've got a older Porter Cable jigsaw; made before they went to China. Heavy metal case; uses a hook-end blade (which I have trouble finding these days) or a universal bayonnet blade (if I swap the clamp 90º).
        Yeah, the blade on a jigsaw wanders, but in my experience usually only at the bottom of the cut. In anything thicker than 6/4 stock, I often get a bit of automatic 'back cut' bevel whether I want any or not. I think you can lessen this effect by going real easy as you cut, but I consider a portable jigsaw a rough tool. I don't expect to get a finish-grade cut out of it.
        Dinosaur
        1. lwj2 | Jun 02, 2008 11:24pm | #53
          Good, I'm not the complete incompetent I was feeling.I'd cut wide of the scribe and at the start (5/4 stock) the damn blade wandered. Sanded most of it out. If Lisa bitches, I'll hit it with a block plane, all it will do is tighten the radius a bit.In retrospect, I should have whacked it in octa or hexa cuts and taken more passes with sander and block plane. I was in a hurry, and we know what happens then.Thanks, Dino -- and I hope thing are going well for you.Leon
        2. Shep | Jun 02, 2008 11:47pm | #54
          If you want a jigsaw that will cut square,  get a Festool.
          I've tried any number of jigsaws. I still have a Porter-Cable like yours down in my basement (want a spare?), I've used a Makita, DeWalt, and also owned a Bosch.
          None of them held a candle to the Festool. With the proper blade, and the blade guides set properly, I CAN cut 90 deg. to the face, even in 8/4 oak.
          Yeah, its pricey. But so is my time futzing with the cut from one of those other jigsaws.
            Dinosaur | Jun 03, 2008 01:42am | #56
            If it was almost anybody else but you saying that, I'd think they were fulla. But I still have trouble imaging it. A jigsaw blade that ain't flexible is almost a contradiction in terms.
            What kinda kerf is that Festool taking out of the wood? ¼"?
            Dinosaur
          2. Shep | Jun 03, 2008 06:07am | #62
            Only about 3-32"
            I'll bring the Festool out to Doud's this summer, if'n yer interested. I'm sure he's got some wood we can "borrow" to cut up.
            The Festool blade I use for the cuts in heavier stock is a little thicker, and a lot stiffer, than the Bosch blades I use most of the time.
          3. Piffin | Jun 03, 2008 06:16am | #63
            I'm impressed what i hear from you. I don't think of you as someone who exaggerates and Festool is good stuff!I cut my tails for my house to look much like the style Forrest shows, but from 4x8, with a Bosch and a 6" blade. Very little wandering. I found that a lot was in the patience of the guiding hand
          4. Shep | Jun 03, 2008 06:27am | #64
            Yeah, even with the Festool, you have to take your time cutting heavy stock.
            But its much easier than with any other jigsaw I've tried.
            My dad had this POS Craftsman jigsaw when I first started working. I don't think that thing could cut square in 1/4" plywood. I've progressed quite a bit since then.
          5. Piffin | Jun 03, 2008 06:29am | #65
            Yeah, you really have to be patient with a Sears or a B&D
            mmoogie | Jun 03, 2008 07:18am | #66
            >>The Festool blade I use for the cuts in heavier stock is a little thicker, and a lot stiffer, than the Bosch blades I use most of the time. <<I buy the Festool blades for my bosch. They are cheaper than most of the other blades out there. Don't like my Bosch. Wanders in the curves pretty badly.Oh, and I usually freehand on the table saw, with the blade set to a 5 degree back bevel if it occurs to me to do it, and finish with a block plane. Though I have used many of the other methods mentioned as well. And I am very respectful of anything with a cutter on a motor, ever since my skill saw kicked back and took 54 stitches worth of flesh and the feeling in two fingers out of my left paw. I do the pool-cue stance like basswood. I never stand in the line of fire of potential kickback.There is one really dangerous move that I occasionally use on the table saw, and that is this: I will on very rare occasions feed a piece in from the outfeed side for an inch or two or three. It puts me in cold sweat to do it, but sometimes it's just gotta be done. Think door head casing with an integral beaded edge...Steve
          7. User avater
            Dinosaur | Jun 03, 2008 08:10am | #67
            Why not just use a hand saw? For an inch or so it won't wear your arm out. (I know, I know; I never think of my hand saw till afterwards either, LOL....)
            Dinosaur
          McDesign | Jun 03, 2008 12:44am | #55
          Great saw - using mine all day to pergolate 8/4 cypress beam ends.  Hook-end blades and all.
          Edited 6/2/2008 5:44 pm ET by McDesign
            Dinosaur | Jun 03, 2008 01:55am | #57
            Yep, mine PC's a work hog. Grunts through about anything without complaining.
            I remember burning out my poor lil' Rockwell cutting quadruple-stacked ¼" beaver barf for some Dino-nasty HehV-DooT anti-bug&animule soffit vents. Took all morning to cut 16 pieces for one soffit and then the motor gave up the ghost and the bearings seized with a shriek that broke the glass outta the houses on both sides of me and a great mushroom cloud erupted into the sky bearing a humongous red R for ROCKWELL
            Ran down to the local hware at lunch and bought the PC to replace it. Came back, ate my Dagwood and Mae West, and cut out the other 15 pieces in about 45 minutes.
            Musta been the new blade that came with it, ya think?
            Dino--Remembering the old green Rockwell that died so hard....
            Dinosaur
            McDesign | Jun 03, 2008 02:13am | #58
            Here's 6 of 14 -
            Edited 6/2/2008 7:14 pm ET by McDesign
            Dinosaur | Jun 03, 2008 02:43am | #59
            What? You don't have a big whacking shaper bit to cut that profile cross-grain in one pass? Shame on you....
            Dino--imagining a Sikorsky shaper.
            Dinosaur
            McDesign | Jun 03, 2008 04:17am | #60
            Yep, but I just can't lift it alone.  It has a 5x4.75" (Chevy) bolt pattern, and I just jack up the truck and take off a wheel.
            Dinosaur | Jun 03, 2008 04:22am | #61
            ROAR!
            Dinosaur
  5. Pelipeth | Jun 01, 2008 01:40pm | #5
    Bosch Jig saw, as they are a great tool, and have a great assortment of blades, then the belt sander.
    1. calvin | Jun 01, 2008 03:22pm | #6
      I've gotten used to running most scribes freehand on a table saw (if set up).  Jagged cuts with a jigsaw-fine tuned w/belt sander or grinder.
      Recently on tall kitchen cab wall scribes I used the festool guide, moving the guide as the line changed direction.  On the tall fills with maybe 3 or 4 straight changes, this worked well.A Great Place for Information, Comraderie, and a Sucker Punch.
      http://www.quittintime.com/
      1. Piffin | Jun 01, 2008 11:34pm | #25
        Wait a minite!Festool has a guide?
        1. calvin | Jun 02, 2008 02:43am | #37
          Well I figgered if I said '' cutting system '' people would have a hard time understanding.
          or
          yes, and a very nice man he is.A Great Place for Information, Comraderie, and a Sucker Punch.
  6. Danno | Jun 01, 2008 04:29pm | #7
    I agree with those who said jigsaw and belt sander. If the scribe line isn't too wiggly, can use a cordless circular saw for the rough cut and then belt sand. Reasons?--easy, tools readily available, works well. You can do a slight back bevel too with the sander.
    1. Yersmay | Jun 01, 2008 05:38pm | #8
      MSA1,In your post you said that you 'freehanded it on the tablesaw.' This is a terribly dangerous thing to do. I hope you'll invite people with much more experience than me to give you some input on this. I don't mean to be the resident 'grandma' but it sure seems like a great way get beaned by a bad kickback.
      1. dustinf | Jun 01, 2008 06:28pm | #10
        If it's above your comfort level that is fine, but just because it scares you doesn't make it unsafe for somebody else.
        I've free handed thousands of cuts with my table saw.  I don't think it's any more unsafe than cutting with a circular saw.  Only difference is the blade is sticking up instead of down.
        If you try to make a 90 degree turn in the middle of the cut you might have a problem, but that's the case with any saw.It's not too late, it's never too late.
        1. Danno | Jun 01, 2008 07:33pm | #11
          I don't really have a dog in this fight, but I don't like to see potentially dangerous advice go out to possible novices without a little note of caution. Table saws are noted for causing injuries--at least I am more aware of their potential for causing injury than the potential of many other tools, including circular saws.
          Freehanding with a circular saw has less problems because the user is controling the saw and if it kicks back, he (we hope) has been careful to keep his body parts out of the way and only has to control the saw. With a table saw, the user has to manipulate the countertop or whatever he is scribing, keep it from binding the blade of a probably more powerful saw, keep himself out of the way of the offcut that may be propelled violently toward him, keep his hand away from the blade and so on.
          That said, a "jigsaw" (saber saw) is probably the safest, as it is running slower, won't kick back, stops quicker, has less blade width in the cut so it can make tighter radiuses without binding, and so on.
          More power to you if you can use a table saw to freehand scribe cuts, but it's maybe not for everyone.
          1. dustinf | Jun 01, 2008 10:17pm | #17
            I wasn't giving advice.  I was stating how I do things.  In the end we are all accountable for what we do.
            If someone wants to sue  me for a statement on this board, let them try.  Until then, I'm not going to let that dictate what I do or say.
            I don't see how cutting freehand on a table saw is any different than cutting with a circular saw, or anything else for that matter.  If you do something stupid with a utility knife it can kill you.
            I'd bet that more stitches come from kitchen knives every year than table saws.
            If you don't feel safe, don't do it.  Period.  No different than anything else.  Safety is a subjective thing.  I've seen roofers walk 12/12 roofs 150' in the air.  I wouldn't do that for any amount of money, but from their perspective it is safe.  Who am I to argue?It's not too late, it's never too late.
          2. Piffin | Jun 01, 2008 11:56pm | #28
            Do you work with any prefinished baseboard? A lot of mine is. Dragging the shoe of a circ saw over it would not be kind.But I also wonder how the guys who try to scribe with a hand held circ sa try to control the wood from kicking out and away. I find better control with the TS for this, and I keep the good side up so it doesn't scratch.
          3. DougU | Jun 02, 2008 01:16am | #34
            If I'm scribing a piece that goes in-between the wall and a tall cabinet (like a 80" scribe for eg)I either clamp the scribe down or nail it down. I then take my circular saw and hold it at an angle, thus allowing a back cut,no need  to tilt the bed for this, your not trying to make a pretty cut. I can cut right up to the line or at least pretty damn close. I then tune up the line with either my hand plane or right angle grinder. Never once dragging anything across the finished scribe!
            I have ran scribes, casing where it meets the wall in a corner, numerous other things across a table saw freehand, just pay attention, this should be the advice for running any power tool, further more, if it don't feel comfortable for you to do, don't do it!
            That last paragraph wasn't for you Piff, for all the novices out there.
            And Sveney, your post was dead on!
            Edited 6/1/2008 6:18 pm ET by DougU
          4. Piffin | Jun 02, 2008 01:24am | #35
            Sven hit the mark dead on.
            JourneymanCarpenterT | Jun 02, 2008 01:34am | #36
            Too bad none of us have any videos.  It would be a whole lot easier to see which technique is the best.  Oh well.-T
          6. Piffin | Jun 02, 2008 12:36pm | #44
            which is best depends on a lot of factors. There is no best for every situation and every person.Depends how much workspace is available and what tools you are most comfortable with.For instance, the TS that some are not comfortable using freehand. Or the only space available to set one up might be out in the driveway.Maybe the guy who uses the belt sander just tore up his last good belt for it, or maybe the blades for my power plane went bad...So we pick up the tool that works. It is good to be versatile.
        2. McMark | Jun 01, 2008 07:38pm | #12
          If you want to free hand with a table saw, that is fine with me.  But it is commonly accepted that it is a dangerous practice, for good reason.  If you want to argue that with your superior skills, you are somehow better, safer and smarter than everyone else, go for it.
          It is very different than cutting with a circular saw.  For one thing, circular saws are designed to be used in that fashion.  Secondly, with a circular saw, you have the motor between you and the blade.  Depending on the size of the piece, there is often not much between your hand and the blade, except for a little wood.  Free handing on a table saw increases the chance of a kick back greatly, as well as stuffing body parts into the blade.  To argue otherwise is stupid.
          But your skill level is so great, that these rules do not apply to you.  Even though these common sence guidlines where developed by people who have been working in the field years longer than you have been alive.
          Edited 6/1/2008 12:41 pm ET by McMark
          1. Svenny | Jun 01, 2008 08:01pm | #14
            When the safety police come out it's difficult to defend any practice without sounding like a reckless cowboy.Freehanding scribe cuts on the table saw is SOP for me, and it is "common practice" among every professional carpenter I have worked with. I know the limits of this kind of cut (you scribe gentle curves such as baseboard to floor-not scribe cuts against stone walls).Every answer on this board is not for novice carpenters.I resent it when others posters feel the need to say certain advice shouldn't be given out because some novice might read it and hurt himself. Power tools are dangerous. Novices should stick to hand tools or hire out their work if they don't care to invest the time it takes to learn how to safely perform procedures such as this. Anyone here see what happens when a circular saw kicks back, and the blade guard doesn't retract before flesh meets blade? I have, and I would never tell a novice to scribe cut with a circular saw. I would never tell a novice to scribe cut with a grinder. A novice can get a terrible abrasion if he tries to scribe cut with a belt sander. I've seen a guy split a finger with a jig saw, so novices beware!In fact to all you novices out there-scribe cut with hand saws only, or maybe better yet with a course file. Sure it may take a little longer, but at least you'll be safe.John Svenson, builder,  remodeler,  NE Ohio
          2. dustinf | Jun 01, 2008 10:26pm | #18
            Wow.  Your wit and intelligence are unmatched.
            I formally retract everything I've said.  Your pointless argument has convinced me I'm too young to know anything. It's not too late, it's never too late.
          3. MisterT | Jun 01, 2008 10:37pm | #21
            I bet he doesn't have a proper blade guard, splitter and anti kickback palls on his job site table saw.I usually will take the big meat off with the table-saw and finish with a hand plane.but I have been known to use a circular saw, a grinder, belt sander, jigsaw a sanding block and even a utility knife.You gotta get it done some how....
            "After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
            If Pasta and Antipasta meet is it the end of the Universe???
          4. Shep | Jun 01, 2008 10:59pm | #22
            Do like I do-
            freehand on the table saw, and don't tell anyone that you do so.
            That way, the OSHA narcs won't complain
          5. dustinf | Jun 01, 2008 11:20pm | #23
            I normally don't get involved, but I'm bored today.It's not too late, it's never too late.
          6. MSA1 | Jun 01, 2008 10:33pm | #20
            Superior skills kill.
            I treat my power tools with great respect.
            Life is not always safe. Having said that, I dont invite danger, but I think that careful respectful use of my tablesaw is acceptable.
            Edited 6/1/2008 3:34 pm ET by MSA1
          7. User avater
            basswood | Jun 02, 2008 12:56am | #32
            I also scribe relatively strait lines with a table saw...especially cabinet fillers. I use a Zen-like concentration and a very smooth motion, like lining up a shot with a pool cue...left hand holding the front edge of the table saw and acting as a fence for the board being scribed...right hand like pushing the pool cue in slow motion...finish with a rubber Vermont American "push stick."Tricky profiles scribed with a RAG with sanding discs (hogged out with table saw or power planer first)
          8. MisterT | Jun 02, 2008 01:03am | #33
            Some here had a tag that read:measure with a micrometer, mark it with a crayon, cut it with an axe....and then theres always the old reliable:cut the bulk of the waste with an adze and finish it with a block plane.Then if will look half adzed...badoom boom tishhhh.
          9. Piffin | Jun 01, 2008 11:45pm | #26
            I would not want to fight over it, since it is true that freehanding with a TS can be dangerous, but I have done it as long as I have been using a TS and never saw it cause a problem.Maybe I'm just standing in line for my next injury, maybe not. Definitely not the best idea to recommend for novices tho - or for having a setup with a window in the background.But of the things that can lead to kickback, I don't see freehand shaving a hair off a board as one of them.The reason though that I use a power plane is to avoid the use of two tools for one job. Most of these replies call for using a saw of one kind or another to make the cut close, then fine tune with a block plane . That is two steps, two tools, and two positions. Most of my trim setups involve a folded leg table with the chop saw on it and a table clamp at one corner. After I scribe the wood with the pencil, I flip it into position, and clamp it, then grab the plane and worry the material off. I can do that faster than using two diff tools and too diff setups.If it is only a hair I do it with my block plane while still on my knees.I'm thinking baseboard here.When it comes to scribing stone or logs at walls, we are on a whole different line of thinking.If it is a lot, I might lay it over the TS if that is handy
        NickNukeEm | Jun 01, 2008 08:47pm | #15
        I used to think the same thing, that free-hand cutting on the TS was an accident waiting to happen.  And if you're not careful, it could be.
        I only freehand with the grain, not cross-grain cutting, which would invite disaster.  And only relatively straight lines.  If I have to cut a circle, I'll use a jig saw.  But for ripping when the cut line is not parallel to en edge, if done with care, freehand works great.
         "I am the master of my fate, I am the captain of my soul."  Invictus, by Henley.
        1. JohnCujie | Jun 01, 2008 09:43pm | #16
          I think you can freehand pretty safely on a portable job site table saw. Hardwood flooring guys have been doing it for years. I don't think it's wise on a real shop size table saw with power. John
        2. DonCanDo | Jun 02, 2008 03:34am | #38
          Could you explain this?  I rarely freehand on the table saw, but when I do, I will rip or cross-cut as needed.  I am extra careful when cutting ALMOST with the grain because the blade will want to follow the grain rather than my desired line.
            NickNukeEm | Jun 02, 2008 04:54am | #39
            I watched a guy cross-cut a piece of pine 1x free hand.  As he tried to guide the work thru the blade, the blade bound and shot the piece into his gut.  I had to turn off the saw and help the guy off the floor.  My only theory is that the blade is more prone to binding when cross-cutting than with ripping.  That's my theory, unscientific and unproven, and you're welcome to do with it as you please : )
            Be safe.
          2. Piffin | Jun 02, 2008 12:42pm | #45
            "the blade will want to follow the grain rather than my desired line."Sounds like you need a sharper blade
          3. MisterT | Jun 02, 2008 02:12pm | #46
            or turn the board around...planing 101: Plane with the uphill grain.
          4. Piffin | Jun 02, 2008 02:17pm | #47
            I thought he was talking TS blade following the grain
            NickNukeEm | Jun 02, 2008 02:22pm | #48
            He was.
          6. DonCanDo | Jun 02, 2008 02:29pm | #49
            I was.  Even with a sharp blade, I find that the blade will tend to follow the grain a little bit if a board is being cut just slightly off from parallel with the grain.  It's a very subtle effect and it doesn't happen with tight-grained wood (like maple), but I notice it with pine where there are alternating soft and hard growth rings.
            It's not really a big deal, but it is one of those times that I'm extra careful when making freehand cuts on a table saw.
          7. MisterT | Jun 02, 2008 09:32pm | #52
            maybe turn the blade around???
            was someone using it for vinyl???or is is one of those ultra mega micro thin kerf blades that can rip tin foil on edge??.
      3. MSA1 | Jun 01, 2008 10:30pm | #19
         I was waiting for you.
        Did I mention that i'm also naked and drunk while doing this?
        Finally, I make sure the safety glasses are neatly put away so I wont damage them with flying debris.:>)
  7. User avater
    Ted W. | Jun 01, 2008 05:59pm | #9
    Whatever is the best suited saw available at the time to remove the bulk, if necessary, then the angle grinder with sanding pad to fine tune it. Alway back cut (or back sand in this case) for a tight fit.
    I rarely use a block plane for scribing.
    Cheap Tools at MyToolbox.net
    See some of my work at AWorkOfWood.com
  8. jc21 | Jun 01, 2008 07:44pm | #13
    I don't think there's any "right" way. For these arthritic old paws of mine a belt sander works the best; Porter Cable's new 371 belt sander is just the ticket- you can run it one handed. A guy I work with is a wiz with a grinder ........... me, I don't do so well.
  9. m2akita | Jun 01, 2008 11:57pm | #29
    Glad you posted this.  I've been thinking about posting something similiar for a bit.
    For long smooth scribes I will you a table saw.  Some of the guys I work with ( newer company to me) would make comments along the lines of me wanting to kill myself.  I did not think that it was that dangerous.  It is how I was taught, how a lot of carpenters I know do it.
    Im assuming that people are scribing in the field, so there is not that big honkin powerful table saw to be worried about ( at least not on the job sites that Im on).
    I will touch up with a block plane.
    For more jagged cuts will use a jig saw.
  10. hvtrimguy | Jun 02, 2008 12:48am | #30
    I've always done the freehand on the table saw to get it close then use a belt sander and/or hand plane to fine tune it. I'm particularly attracted to the new small porter cable belt sander that has been out for a year or so now. looks easy to hold.
    jason
    Bozini Latini
  11. Biff_Loman | Jun 02, 2008 06:15am | #40
    I'm kind of a newb, but:
    Wow. I'm usually (OK, always) quite cautious with the tablesaw and respect it utterly, but would absolutely freehand this kind of cut. I tried it once when my jigsaw died, and it works awesome, and didn't strike me as the least bit hazardous.
    I just don't think that cutting an eeny-weeny bit off something is a recipe for a dangerous situation. I've fired my share of projectiles off the tablesaw when I was first trying to figure it out, and I've learned not to screw around with it, and I always try to make tablesaw operations a little safer: push-sticks, featherboards, whatever. But this is a pretty benign scenario: just take it easy. It doesn't take superhuman skill or brass balls or anything.
    But I've come to appreciate the belt-sander for (in my limited experience) ultimate control.
    Edited 6/1/2008 11:17 pm ET by Biff_Loman
    Edited 6/1/2008 11:20 pm ET by Biff_Loman
    Edited 6/1/2008 11:22 pm ET by Biff_Loman
  12. sunsen | Jun 02, 2008 06:29am | #41
    Yes. The degree of control you have with a block plane is beyond all the other methods available.
  13. sunsen | Jun 02, 2008 06:30am | #42
    By the way, I do back cut whatever I'm scribing somewhat. Makes for easier planing.
  14. jc21 | Jun 02, 2008 07:25am | #43
    Some of the tract homes I remember from years ago I'd see a case of DAP Alex Plus go in the house and an empty box come out ............... guess that was their way of "fine tuning scribe lines".
A Practical Perfect Wall
  • The New Old Colonial
