Deck framing around an angled bay window
tdlann | Posted in General Discussion on August 13, 2011 04:59am
Hi,
Can someone please give some ideas on how to frame a 12′ x 24′ deck around a bay window where the side frames are at an angle as opposed to being at right angles to the house.
Because of design restraints assume the beams have to be at right angles to the house [brick veneer dose not allow a ledger] and because the deck is too close to the ground the beams and joists will be in the same plane using joist hangers.
Hope you can help.
terry
  • Fine Homebuilding's Author Guidelines
