Deck Stairs
tashler | Posted in Construction Techniques on June 17, 2006 01:50am
Building my first deck on my own in 13 years. Questions about the stairs.
Pouring a concrete pad for a landing. pour it before I cut the stringers to give me a set place to calculate, or after, floating the stringers just above the concrete until it dries?
How to cut and set the stringers? By that I mean, I plan on adding 1 tread up to be even with the top of the joists, making it actually part of the deck. I think I prefer that to dropping a fake rim joist and setting the stairs lower, or notching for the rim joist underneath and around back of it.
Does anyone use any hangers when attaching stringers?
Thanks for any replies. I already have the gray hair from worrying about things, I don’t want to lose it scratching my head over this stuff.
    Matt | Jun 17, 2006 02:17pm | #1
    >>  I plan on adding 1 tread up to be even with the top of the joists, making it actually part of the deck. I think I prefer that to dropping a fake rim joist and setting the stairs lower, or notching for the rim joist underneath and around back of it. <<
    By doing that you are going to mess with the way your stair hand rail intersects with your deck guard rail, possibly causing the necessity of a pair of handrail posts needing to be mounted to the side of the top step.  Think it through on paper with a scale drawing, taking into account the desired heights of the 2 rails - guard and stair.
    1. tashler | Jun 17, 2006 02:39pm | #2
      I wouldn't think so. The top tread in essence becomes just part of the deck, so the post can go at the top tread to keep everything in line.
        Matt | Jun 17, 2006 02:58pm | #3
        If you are going to use ~36" high guard rails, it will very possibly cause an issue.  If the deck guardrail posts are set back from the edge at all, it gets worse.  You end up needing a short horozontal section of stair handrail at the top of the steps.
        1. tashler | Jun 18, 2006 01:57am | #4
          Ahh, I see what you're thinking.Picture a square deck. Take of one corner, about 3' in x 6' across. that's where the stairs are going. The outside stringer will attach to the box beam, end grain to end grain. They will be in the same plane. The stairs are actually part of the square, not an add on to it.
    Fonzie | Jun 19, 2006 12:44am | #5
    Tashler,
    We sink posts to support the bottom of the stringers and come on up for the railing.
    If this doesn't work for your style of railing you could hide the short posts under the stringers.
    We use Teko plates/screws on the connection (inside out of sight).
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
