Are propane tankless water heaters easy to drain? I want to install a tankless in my cabin. I use the place on weekends in the winter so I drain my water system when I leave for the week and start it up again the following weekend. I have a photovoltaic system to run a submersible water pump and lights. The winters are very cold in Ontario.
Plumbed correctly, they will drain completely. If you put the tankless above your existing drain point, it should drain with the system. You should probably cut power to it as mine has the water valve OPEN with no power applied.
MERC.
