drilled holes in trusses
bobtim | Posted in General Discussion on May 15, 2008 06:48am
Would have liked to address this to Bosshog, but couldn’t figure out how to.
How big of a deal is drilling holes in the bottom chord of a truss?
I told an owner/builder that he screwed up in a major way by drilling several 1” hole in 2×4 bottom chords and also told him he really  realy screwed up by drilling in the bottom chord of a girder truss (tripled up).
So how big of a deal is this really?
What would you prescribe to fix it.  No rock installed yet.
  1. rez | May 15, 2008 06:56pm | #1
    bump
    Click here for access to the Woodshed Tavern
    Click here to visit the beginning of Breaktime
  2. rez | May 15, 2008 06:59pm | #2
    but couldn't figure out how to.
    Press 'Others' in the To: listing and then type in the name of the poster the post is to be sent to then click 'OK'.
    Cheers
    BossHog | May 15, 2008 07:43pm | #3
    It really depends on the truss and where the hole is. Every case is different.
    If a customer called me to say he had a hole drilled in a truss, I would look at the hole location and how stressed the truss member was at that point. It could be that it was no big deal at all, or it could be fairly serious.
    Girder trusses are a bigger problem for two reasons - The lumber is often pretty maxed out, and they're harder to repair. You often can't get enough plywood on them if they actually need repaired.
    As for the person that you mentioned who has apparently done this to some trusses - The best thing he could do is contact the manufacturer. They'll need the exact location of the holes, their diameter, and where they're located in the chord. (Centered, closer to the top, or whatever)
    They'll have engineers that they can run the information by who will prescribe a repair if it's needed.
    Why is bread square, when most sandwich meat round?
  4. tuolumne7 | May 15, 2008 09:36pm | #4
    It could potentially be a huge deal depending on location.  A 1" diameter hole just took out nearly 30 percent of the member capacity.
  5. semar | May 15, 2008 10:13pm | #5
    If I was the GC on the project I would reject any liability. In writing!!!
    In any case the building inspector would want to see an engineer's report
    All truss specs I have seen specifically state that no modifications or drilling is allowed. Even plywood "floors" for future storage can change the load specs dramatically.
    If something happens the insurance co will void any claims for sure
  6. frammer52 | May 16, 2008 12:57am | #6
    go out and buy a bolt to fit the hole!  quick!
    1. FastEddie | May 16, 2008 02:15am | #7
      I bet you could use tan caulk too."Put your creed in your deed."   Emerson
      1. frammer52 | May 16, 2008 03:39am | #8
        yeh that works too!
      2. bobtim | May 16, 2008 04:31pm | #9
        should the caulk be paintable???
        Thanks to everyone for their replies.
Critical Details for Ductless Heat Pumps
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
