drywall ceiling repair with heat cabling
dfmcintyre | Posted in Energy, Heating & Insulation on October 5, 2004 11:13am
We recently had a water leak in the master bath that dripped onto the first floor ceiling. Opened up the ceiling drywall (carefully, you’ll see why below), determined it was from the shower pan, not the toilet, and repaired the problem.
The ceiling is roughly 7/8″ thick; rockwall attached to the joist(?) followed by heat cabling, then another sheet of board and then a finish coat on it.  The hole I made, to eliminate the water damage is about 6″ diameter. The wiring is approximately 2″ o.c.
Question is how to reconstruct the ceiling, keeping the exposed heating cable in place.
Thanks – Don
    NickNukeEm | Oct 06, 2004 01:17am | #1
    Normally you can cut a piece of drywall as a patch, sized about 2-4 inches larger than the hole to be filled.  Outline the hole on the back of the drywall, cut it out, but leave the front face intact to act sort of like a flange.  Mud up the paper flange/edge of hole, apply patch to hole, and coat as required.
    Often I insert some sort of wood support glued/screwed to the drywall prior to appling the patch, but your cable wouldn't lie flat if you did something similar.  The paper flange trick should work, provided the patch isn't too big.
    Anything you can think of that might prevent this from working?  (Only you know for sure what the situation is...)
  2. Mooney | Oct 06, 2004 01:27am | #2
    I agree with Nick.
    6x6 inches can be held by a drwall patch with backing screwed such as plywood . Two 1 1/4 inch strips of plywood and SR screws make a good job.
    But as Nick says , were not there to see it .
    Tim Mooney
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
