I am drywalling my basement and will include some soffits to hide pipes and heating ducts.
When doing the soffits, should I install the tapered drywall edges on the inside or outside corners, or does it make any difference?
Thanks.
Doc Richard
Thanks.
Doc Richard
doesn't matter. Usually the cut edge in the corner. For example if your soffit was 36" wide you would have at least one cut edge. Unless you had a seam in the middle with tapered edges in the corners which to say the least is highly unorthodox and a waste of time.
It depends on which corner you want to be non 90 degrees.
Some think the protruding bead on top of a cut edge makes the corner curve out too much, but as far as I know it's personal taste
Jake Gulick
[email protected]
CarriageHouse Design
Black Rock, CT
Doc,
Please don't put the tapered edge on an outside corner!
Makes for a Royal PITA to run the bead!
If your using round bead, hold the DW back 3/8" on outside corners.
Yes it does make a difference. I'd have to say I agree with G80104. The corner bead needs to be flush with the board. At the very least, one side of a corner should be without a tapered edge. Install the tapered drywall edges on the inside corners only.
The best way to hang a soffit is to put the tapered edge up. Unless of course the soffit is so short you can avoid a tapered edge all together. This way the tapered edge hits the ceiling, just like if you were hanging a wall. You'll have a cut edge at the bottom on either side.
For the bottom, score past the tapered edge. Then score the remainder of the sheet the widths you need underneath the soffit. This way you'll be able to hang cut edge to cut edge. If the bead is square, cut the lids about 1/4" shy of the total width.
Click in my signature for additional drywalling tips.
-T
Edited 11/27/2005 5:57 pm ET by JourneymanCarpenterT
Edited 11/27/2005 5:58 pm ET by JourneymanCarpenterT
Tapered edges are meant for joints between boards.....not inside or outside corners.
While they may not be a problem at inside corners, they`re a definite no-no at outside corners.
J. D. Reynolds
Home Improvements
