dumb grinder question
ndege | Posted in Tools for Home Building on May 4, 2005 04:54am
I’m looking at buying an 1800 RPM grinder for use on chisels and such. Will this be sufficient for heavier work? Mower blades, mauls, etc.
  1. VaTom | May 04, 2005 05:23am | #1
    It'll be slow, depending partly on what wheel you have.  Ideally, you have 2 grinders.  Or choose the one that's more important to you.
    I couldn't manage without a slow grinder.  Heavy steel, I either use an angle grinder or am patient.
    1. ndege | May 04, 2005 05:45am | #2
      Yeah, I've been using an angle grinder, but patience is good, too.
    oak | May 04, 2005 08:46am | #3
    would something like this work out for? there is a 6" and 8" model...
    * Electronic variable speed from 2,000 to 3,450 rpm
    http://www.amazon.com/exec/obidos/tg/detail/-/B00006K002/102-5865887-7944927
    Delta GR250 Shopmaster 6" Variable Speed Sharpener/Grinder with Lamp
    Other products by Delta
    Edited 5/4/2005 1:48 am ET by oak
  3. steelbuddha | May 04, 2005 03:52pm | #4
    Get a Tormek for your chisels and a regular old bench grinder for utility sharpening. The two tasks don't really mix.
    1. ndege | May 04, 2005 04:04pm | #5
      Yep, Buddha. That's pretty much my conclusion. I'll have to get a second mortgage for the Tormek, but it looks great! : )
