DW 998 18V. Practical experience.
Driving screws, working fine, THEN:.
Pulled the trigger, NOTHING
So, figured just getting corrosion on terminal, pulled battery and slammed home, still no action
Dissassembled : The ‘fast-on’* lead to the battery had overheated and melted the nylon insulator, shorting the batt.
OK, cleaned and soldered the ‘fast-on’ terminal, 5 min epoxy where the nylon melted.
Reassembled, all OK. BTW, since it was apart, soldered all the ‘fast-on’ clip connections – slightly more power even getting rid of the contact resistance of the stupid ‘fast-ons’.
* If you are not familiar with the ‘term ‘fast-on’, it is the spade terminal that has a clip go over it. Whenver I repair anythign with those, first thing is they get soldered. Just last year I ran into a 3 megwatt Cat DG set that shutdown due to an overheated ‘fast-on’ in the control circuitry and a 100kW uninteruptible computer power system that shut down due to a loose ‘fast-on’. Cheap for mfg flow times, but poor technical choice for any type connection.
EDIT BTW: got the DW a couple years ago at a garage sale, worked OK, guy said he was selling it ’cause it ‘cutout’ occasionally. Worked OK for me (only occasional use every week or so, nothing professional) for over a year till last week when the problem occured again.
Edited 7/18/2009 10:48 am ET by junkhound
"EDIT BTW: got the DW a couple years ago at a garage sale, worked OK, guy said he was selling it 'cause it 'cutout' occasionally. Worked OK for me (only occasional use every week or so, nothing professional) for over a year till last week when the problem occured again. ''
Funny, I found my wife at a small boutique type shop.
"If Brains was lard, you couldn't grease much of a pan"
Jed Clampitt
