Electrical Contract Question
runnerguy | Posted in General Discussion on October 6, 2007 08:38am
I’m in the middle of building my own house and I have a question regarding the contract for the electrical work.
Basically, the contract lists all the stuff in line item form. There are 30 line items. Most of the stuff is self evident like “Install wiring for electric burner top”, “Furnish 6 TV prewires”, “Install 2 weatherproof recepticles”, “Install wiring for 2 flood lights with 4 switches”, “Furnish 29 recess lights”, etc.
However the line item “Install wiring for 196 outlets which includes all regular light, switch, recepticle, and bath fan outlets”. What would this be intrepreted as meaning??
I have my own opinion and I think I know what it means and I’ll expand on that in a follow-up post but I want to get unbiased “raw” opinions from those more knowledgeable first.
Thanks,
Runnerguy
  1. edlee | Oct 06, 2007 10:23pm | #1
    Well, an outlet is defined as any place that electricity is utilized, though informally it often is used to refer to switches also. This is in contrast to what many people (wrongly) mean when they refer to an outet: a receptacle outlet.
    So he's using electrician's terminology to tell you that all the basic switch, light and receptacle outlets in the house add up to 196, including the bathroom fan hook-ups.
    He's likely excluding hard-wired appliances, 240v outlets for appliances, maybe smoke/CO detectors, etc.
    Ed
    1. runnerguy | Oct 07, 2007 01:53pm | #3
      Thanks Ed. That is what I was figuring. Yes, the other line items all reference the main panel, doorbell, disposal, dishwasher and similar appliances, furnace, paddle fan prewires and such.
      So against the 196 allowance, a switch to a light would count as 2, 2 X 3 way switch's to a one light would count as 3, 2 X 3 way switch's to  two lights would count as 4, etc.
      Thanks,
      Runnerguy
      1. edlee | Oct 07, 2007 02:29pm | #5
        Yes, that 's how I do my bids and estimates, based on a cost per opening (or outlet).
        So if at the end of the rough-in, with the inevitable changes in design, he tells you you now have say 205 openings, the extra cost would would be 9 X (unit charge per opening).
        Ed
    BillHartmann | Oct 06, 2007 11:02pm | #2
    I would probably want to refer to a schedule that will give more detail with showing each wire and box. That still leave a lot of leeway such as how bathrooms will be wired.
    For example;
    Living room;
    5 wall mount receptacle, 2 split for switched lighting
    1 mantal receptacle.
    1 receptacle on dedicated circuit for audio/visual
    2 can lights (over fireplace) on one switch.
    4 can lights on one switch.
    5 switches.
    1. runnerguy | Oct 07, 2007 02:01pm | #4
      Thanks Bill. Your method would be better but I got the bid when I was establishing the budget and it turned out I went with the guy. That's probably why this "allowance" method. And of course, between then and now we've made some changes (albiet minor) to the plan) I just wanted to be sure I was looking at it correctly, especially the 3 way and 4 way switches.
      Runnerguy
Drafting the 2027 IRC
  • The New Old Colonial
