I’m looking for information on installing end grain wood block flooring. Specifically on what grout to use. I have seen some commercially prepared products but they were pretty expensive per sq. ft. I seem to recall seeing a formula for mixing sawdust (from cutting the blocks?) with an oil based finish, or finishes, & using that as the grout. Has anyone heard of this or seen it done anywhere?
I assume that whatever is used would have to remain flexible enough to absorb the movement of the wood but still dry completely enough not to be a fire hazard or a source of spontaneous combustion (the oily rag theory)
From plumbing failures to environmental near disasters, OHJ staffers dish on our worst and best moments.
I'm looking for information on installing end grain wood block flooring. Specifically on what grout to use. I have seen some commercially prepared products but they were pretty expensive per sq. ft. I seem to recall seeing a formula for mixing sawdust (from cutting the blocks?) with an oil based finish, or finishes, & using that as the grout. Has anyone heard of this or seen it done anywhere?
