Using “sign” board (mdo) to construct a piece that will be outisde. What epoxy would people suggest to seal/fill the edges?
Thanks for any help/suggestions. Kieran
The Portascanner uses ultrasonic technology to isolate the smallest air leaks, making it easier to air-seal an enclosure.
I don't. It's already made with ext. glue. But if you wish, go with West Systems. It must be painted tho' epoxy breaks down in UV light.
"If Brains was lard, you couldn't grease much of a pan"
Jed Clampitt
I would trust your opinion so if you don't feel the need to seal, I am not going to create more work for myself.
Thanks. Kieran
Unless it would be practically submerged, it is unneeded as a rule. Prime and paint will do ya fine.Spheramid Enterprises Architectural Woodworks
Thanks again. I always appreciate the expert input. Kieran
The 'sign' board that I use for my professional signs is Omega (aluminum sheet laminated both sides of plywood) - I sandwich it (frame it) all around with Azek brickmold both sides - done deal.
I used MDO for a pontoon blat deck (19 years ago, 6000 hours over salt water)
Seal the edges and any penetrations with a real good paint (I used a poly fortified enamel) it will hold up forever.
The only bad spot I have was a penetration I made later and didn't seal.
Thanks. Any particular brand of paint you recommend?
I used Red Devil poly urethane enamel but I haven't been able to find it lately. I really liked that stuff. Some T 111 I painted with it about the same time in 1990 is still looking great. I guess it was too good.
