b What is best for milling exterior trim mouldings.
A debate ensued over a current project. The question what should be used for milling a 7″ exterior crown. I felt In our area (Chas.SC.)southern yollow pine was a good choice. The architect feels cypress is best. Our supplier says yellow pine pressure treated after milling or cedar is the correct way to go. Problem: western red cedar is hard to find in sufficient length and size, redwood is currently in limmited supply. What are your thoughts, suggestions or oppinions.
For the species you've mentioned, I'd prefer the cedar or cypress over the SYP, regardless if the SYP is treated or not treated.
As an aside, the humidity/environmental swings in your part of the country could wreak havok on a 7" exterior crown, considering the width vs. thickness ratio. You may (my opinion) want to consider building the 7" crown up from smaller stock for added strength and stability.
You've mentioned the preferences of all except the builder (unless that's you?). Has the builder given any input based on experience in your climate?
Does anyone have experience with Georgia Pacific Prime Trim that is advertised in this month's issue? Easy to work, or special tools/technics? Cost comparison to wood, fiber cement, Fypon? Weather resistance?
A debate ensued over a current project. The question what should be used for milling a 7" exterior crown. I felt In our area (Chas.SC.)southern yollow pine was a good choice. The architect feels cypress is best. Our supplier says yellow pine pressure treated after milling or cedar is the correct way to go. Problem: western red cedar is hard to find in sufficient length and size, redwood is currently in limmited supply. What are your thoughts, suggestions or oppinions.
Shannon,
It's been my experience that pressure treated lumber does not hold paint well.
I would say cypress or SYP would be the most cost effictive if you want real wood.
Personally, I prefer mahogany for exterior trim.
Ed. Williams
