Fencing material question
Len | Posted in General Discussion on April 7, 2005 07:54am
Gents,
A number of split rail fencing around our neighborhood is rotting. There has been a lot of talk about concrete “wood” by my HOA. The fences are decorative and not meant to hold anything in.
I was wondering what was anyone’s experiance with it. And if anyone could suggest an alternate to using wood.
I was wondering if any of the new composite wood decking products would work.
Suggestions?
Thanks in advance.
Hi, I’m Len and I’m a Toolaholic…
    IMERC | Apr 07, 2005 08:06am | #1
    hello fellow toolaholic...
    we feel yur joy...
    what is the original fencing made from and are they rotting at ground level or all over???
    the synthics (decking materials) seem to make for poor fencing material 'cause of the lack of span support... not familar with the concrete wood..
    WOW!!!   What a Ride!
    Forget the primal scream,  just ROAR!!!
    1. Len | Apr 07, 2005 08:19am | #2
      They are rotting at  ground level and at the joints. I believe it's a landscape maintenance issue. If they would aim the sprinklers away from the fences there wouldn't be as much of a problem. The other issue is general maintenance. They haven't painted for several years.
      Here's one company that makes the concrete wood.
      http://www.californiaconcrete.net/
      So now they would like to replace the fence with "maintenance free" material. Which I know that nothing is maintenance free.
       Hi, I'm Len and I'm a Toolaholic...
        IMERC | Apr 07, 2005 08:41am | #3
        Our site is under renovation. Please call (630) 257-1431 for more information. Thank you for your patience while we make improvements.
        didn't learn too much there... yur right about the sprinklers and the lack of drainage is probably the root of the problem for the rot at ground level... as for the joints.. lack of maint is a good bet..
        do you know the flavor of wood these fences are made from???
        WOW!!!   What a Ride!
        1. Len | Apr 07, 2005 11:36am | #4
          I can't imagine it's redwood. Looks to be rough cedar.  Stuff only lasted for 8 years.Hi, I'm Len and I'm a Toolaholic...
          Sphere | Apr 07, 2005 04:24pm | #7
          Around the south east I see TONS of locust split rail..still good since replaced after Sherman and his boys burnt all the originals during "the recent unpleasantness".
          Locust lasts almost forever, some of the chestnut are still here too.
          "Success, is not pleasing others, it is pleasing yourself"
    2. DANL | Apr 07, 2005 02:46pm | #5
      Maybe concrete wood is like fiber cement boards? (Either that or it's wood cut from petrified trees.)
  2. DaneB | Apr 07, 2005 03:23pm | #6
    Concrete  made to look like wood when done right it some beautiful stuff.  I have seen it.  I could not tell the difference at a glance, but when I tried to shave a piece off to make sure of what I was looking at my knife wouldn't cut it like it would wood.
    It will cost less in the long run if you have to replace the real wood every 5 to 8 years.
    Dane
    I will always be a beginner as I am always learning.
