Hey all, I am need to insulate a 20×8 wall(exterior) in my house.
The wall is Block and brick
I plan to frame it out w/2×4’s 16 oc and was going to use FG , but having read a bit here I am not so sure.
Thanks in advance
-JWS
Thanks in advance
-JWS
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
when I finish basements here in Minnesota, I put 2" ridged foam against the block, tape all the seams and the foam also works as vapor barrier, then stud wall with no insulation and drywall right on studs no other vapor barriers.
Not sure where you are and how much insulation you need - the 2" foam is only R-10 if I remember correctly - that's enough to satisfy code for a MN basement
I think you need to contact Mike Smith about his insul. details.
The new issue of FHB has an article on finishing a basement. It might help you.
There is a special sort of rigid foam that is made for insulating masonary. The edges are notched so you can glue up the foam, then insert 1x3 or some such in the adjacent notches, and "shoot" that to the wall to secure it. Then regular drywall or whatever can be attached to the wood.
No wood in contact with the masonary, no breaks in the insulation, but you still have a good mounting surface for finish materials.
FWIW:
2" Rigid foam is rated at 7-10 R value. $16 - $20/ 4x8.
3 1/2" Fiberglass is rated at 13-15 R value. $.36 - $.54/ sqft.
Do the math.
If the walls are damp - ever - use rigid.
F.
More to the math than just that. It costs more to stud a wall that furr over foam from the lumber aspect. And you can save roughly an inch.BTW, you can have foam that is rated R7 for just one inch. Two gives you R14 and less convective heat loss.
Depends on what your foam is. XPS (Styrofoam) is R-5. Polyisocyanurate is rated R-7.x, but cures to R-6.x. The polyiso boards I see are foil-faced which would not be appropriate in a basement
andy engel just did a great picture article on eps foam and insulating a basement
you could do a lot worse than use that as your modelMike Smith Rhode Island : Design / Build / Repair / Restore
"The polyiso boards I see are foil-faced which would not be appropriate in a basement"I read this to mean that it is the foil-face which is inappropriate for a basement.But why is that??Rich BeckmanAnother day, another tool.
Ok someone correct me if I'm wrong, but I am under the impression that foil facing is a VB. Hence buildingscience.com's admonition to use (unfaced) XPS.
"Ok someone correct me if I'm wrong, but I am under the impression that foil facing is a VB. Hence buildingscience.com's admonition to use (unfaced) XPS."Thanks.Rich BeckmanAnother day, another tool.
I building a media room in my basement and was planning on placing 2" EPS (not foil faced) on the concrete block walls and frame the walls with 2x4's. However, I would like to fill the 2x4 wall cavities with fiberglass insulation to help with resonance and accoustics within the room. Do you see anyting wrong with both EPS and fiberglass insulation.
Thanks,
Brian
That's fine, but use unfaced FG batts. Also, they make a denser FG batt that is supposed to be helpfull accoustically
Ya, the foil face is a VB, but so is XPS.The only reason I can think of for hesitation in using the polyiso foil faced in a cellar is that is is open celled so it can harbor water. It would all depend on whether moisture is likely to be a problem.I just got tyhe latest FHB today and breezed thru the article showing Andy doing his stuff. Didn't read the text,yet but the pics all look like good stuff to emulate.
"...the foil face is a VB, but so is XPS."Not true. Dow will say very carefully that XPS is a vapor retarder, not a VB (so don't sue them if your XPS permeates). Buildingscience advocates XPS without a vapor barrier for basement insulation because any moisture that leaks behind the insulation permeates back....slowly. EPS permeates better but has lower R-value.
Fine enough to be technically correct - but for practical purposes, it functions as a VB, between the low perm and the insulation denying dew points. BTW, there is nothing that does not have some degree of permeability, even waterproof roofing membranes. it is just a matter of using adequate perms where needed.
