I am going to be building a home in a rural area where fiber optic internet is not currently available. The nearest drop for the existing cable internet/TV system is about 500ft away. If I were to place a fiber optic cable,in conduit, in a currently open trench would the cable company be able to connect to it at the utility pole? Would a power source be necessary at the pole? I’ve made several calls to the local provider. They are slow to respond and even slower to arrive at the site. I would like to close the trench so I figured I should have my guys install it.
![](https://images.finehomebuilding.com/app/uploads/2024/07/23115115/FHB-Pod-642-feature-scaled-thumb-16x9.jpg)
Listeners write in about attics, foundations, and dodgy electrical devices. They ask questions about trusses, wet ceilings and siding installs.
You might be better off with empty conduit in the trench, with a pull cable. that way they can use a cable they are happy with.
of course they might decide to run the cable themselves and leave it an inch below your grass, or hung in the air.
