Figuring out a circle
nater | Posted in Construction Techniques on September 12, 2005 07:58am
I’ve got a small project I’m building, and I’m stuck on a semi-circle for my plans. I’m not bad at math, but I’m rather rusty. I have to make a curved cut, and I’ve got three points it needs to go through, and I want to make it a smooth curve throughout. If this was on graph paper, the points would be (0,21);(13.5,13.5);(22,0). I’ve tried looking online, but I’m just confused, and I end up scratching my head for a long time. Short of hiring a math professor, is there any easy way to do this? I just want to figure out what the radius of the circle should be, and I can sort out where the center point is. Thanks in advance.
  1. bbqjason | Sep 12, 2005 08:25pm | #1
    A circle is the set of all points in a plane whose distances from a fixed point (in the plane) are equal.  The fixed point is called the center.  The distance from the center to one of the points is called the radius.  Any of these points, other than the center, is said to lie on the circle.
    Center (h,k) and radius = r
    If a center of the circle is at the origin (0,0) and its radius is r, with P(x,y) representing any point on the circle, then its equation is x^2 + y^2 = r^2
    If the center of the circle is at the point (h,k) and its radius is r, with P (x,y) representing any point on the circle, then its equation is (x-h)^2 + (y-k)^2 = r^2
  2. JTC1 | Sep 12, 2005 09:02pm | #2
    Not a math whiz myself, but based on your "graph paper" points it sounds like you are describing a 90 degree arc rather than a semi-circle.
    Being somewhat math challenged I have devised certain coping behaviors to solve problems such as yours.
    In your case I would draw the problem, full sized or scaled to something manageable, the bigger the better.
    1) Accurately plot the three known points which you need to hit.
    2) Set a beam compass or a pair of trammel points to a rough radius, sounds like it is about 21.5 "units" (inches, feet, cubits or whatever).
    3) Scribe an arc in the vicinity of your center from all three known points.
    4) Adjust the length of the radius on the beam compass or trammels until all three arcs hit a single point.  This will probably take several tries.
    5) The resulting single point is the center and the length on the beam compass/trammels is the needed radius.  Results are easily confirmed by swinging your radius from your "found" center and checking for a hit on all three of your start points.
    I know it is not very scientific, but it works on any circle or part thereof.
    Good luck!
    Jim
      nater | Sep 12, 2005 09:49pm | #3
      I finally figured it out... I finally found a calculator online that does it automagically. I can enter in the x,y coordinates for each of the three points I want the circle to point to, and it determines the radius of the circle, and the center point of the circle.Located here: http://home.att.net/~srschmitt/script_circle_solver.htmlI can now figure out exactly how make my circle come out nearly perfect when I cut. Thanks for your time
      1. JoeBartok | Sep 14, 2005 12:19am | #4
        nater: I'm running out of time and have to log off soon, and it's water under the bridge anyway since you have a solution. But here's as far as I got with your question (hopefully correct! I did this in a hurry):
        I took the points to be the vertices of a triangle and solved for the three sides using the formula Square Root[(x1- x2)² + (y1- y2)²] obtaining lengths of 30.41381, 15.44345 and 15.95306. Then I solved for the radius of the circumcircle that passes through the vertices and got a radius of 31.616102. Judging by your points your circle is "off center"; I haven't figured out how much at this time.
        If you're happy with a graphical solution you can also solve for the center geometrically by connecting pairs of points and finding the perpendicular bisectors of the lines. The bisectors intercept at the center of the circle.
        I'll make a note of your points, play around with this problem later tonight and post what I think is the correct answer tomorrow.
        Joe Bartok
        Edited 9/13/2005 5:24 pm ET by JoeBartok
        Edited 9/13/2005 5:25 pm ET by JoeBartok
      2. Renovator | Sep 15, 2005 01:47am | #10
        Hi Nater;
        Start in your corner .785 x D squared
        Edited 9/14/2005 6:49 pm ET by Renovator
    Sphere | Sep 14, 2005 02:14am | #5
    A tall stick and the sun works too..make a sundial.
  4. FastEddie | Sep 14, 2005 02:18am | #6
    Let's see if I got lucky.  I plotted it in AutoiCad using inches for the coordinates you gave.  That resulted in a radius of 2'-7 5/8" with a center point at -8 1/8", -9 9/16".
    1. JoeBartok | Sep 14, 2005 05:30pm | #7
      FastEddie: I think you got lucky and I like those numbers.
      nater: I pursued the math last night and while I was at it made up this Circle Calculator. If you enter the points you gave you'll get the radius I calced yesterday and FastEddie's points for the center. This calculator finds the chords which form a triangle and then determines the intercept of the perpendicular bisectors trigonometrically.
      But there's another way of determining the radius without the trig: Solving the Equations. I only had a few minutes last night and didn't have time to post the information. This process emplys the same circle formula bbgjason posted:
      (x - h)² + (y - k)² = r²
      Hope this helps.
      Joe Bartok
      Edited 9/14/2005 10:35 am ET by JoeBartok
      1. msm | Sep 14, 2005 07:02pm | #8
        thanks for the math links.
        sometimes a perfect circle won't work and you need to ooch it into an oval. here's a cool homemade "trammel point" device to scribe an oval:
        partially sink 2 nails into a surface, for eg, 12 inches apart. tie a circle of twine that, when looped over one nail (your center), reaches past the second nail. how much depends on the size and proportion you want your oval. for eg, 3" past the second nail. make sure both nails are inside the loop and pull taut with a penci. now draw your line keeping the loop taut until you've gone all around. oval! there may be a mth formula to figure your points, but with a little trial and error in the length of the loop and distance between the nails, it's easy to get what you want.
        1. JoeBartok | Sep 14, 2005 09:02pm | #9
          There is a formula for the foci of an Ellipse - but we don't really need it. You can set your compass or trammels to the length of the semi-major axis, place one point where the pencil is shown in the drawing and scribe marks on the major axis. Those are the foci or the points where we place the nails.Joe Bartok
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
