Fire Damaged House Repair
| Posted in General Discussion on September 8, 2000 12:42pm
I just bought a house with minor fire damage, but the residual smell is still in one end of the house. All the interior is out down to the bare studs. What do you recommend to cover the chared joists and rafters (they’ll remain. I’ll be sistering 5 or 6 of each)?
  1. Guest_ | Aug 05, 2000 04:26pm | #1
    Morning John,
    I would sandblast the chared sections clean. First of all, the portions that are burned add nothing to the structural integrity of the house so blasting it off changes nothing but the smell. Secondly, it allows you to "see" the fire damage properly. Sometimes wood can look only slightly damaged but can be toast.
    Afterwards, you could spray with a primer if required and then do your repairs.
    Gabe
    1. Guest_ | Aug 05, 2000 07:52pm | #2
      *John,Ditto Gabe.We finished one this year, and it was a mess.Sand blast the charred wood away, two coats of good primer sprayed, set up an ozone machine for a few days, get all the fire debris out from under the house and you'll probably have to replace all the return air ducts if the A/C was on during the fire. Also, have all the duct's cleaned and replace all carpet and pad, even if it wasn't damaged because it will soak up the fire smell. Call Blackmon Mooring(SP?). They did our job. No smell left.Ed. Williams
      1. Guest_ | Aug 06, 2000 02:26pm | #3
        *I would suggest that unless you remove the burned wood on damp days you will always have a smokey smell in the house. You plan on sistering beside the old joist why not just replace them. Worth the time and extra money.
  2. tezor_ | Aug 26, 2000 05:49pm | #4
    I've been a volunteer firefighter for 20 years, and in the trades for 30, if you don't seal all affected areas the smell never goes away. I mean spray 2X with a high quality sealer, look for the holidays and cover them up, the entire inside attic to subarea-basement needs to be done. It is one of the most persistant smell issues in repair construction. It would be wise to replace all HVAC venting if it is insulated, all insulation, even in seemingly unaffected areas will harbor the smell. On those winter days when the house is closed up, and a little damp it will return with a vengence. Wishing ya luck, T
  3. John_Hartranft | Sep 08, 2000 12:42am | #5
    I just bought a house with minor fire damage, but the residual smell is still in one end of the house. All the interior is out down to the bare studs. What do you recommend to cover the chared joists and rafters (they'll remain. I'll be sistering 5 or 6 of each)?
  4. Guest_ | Sep 08, 2000 12:42am | #6
    John, we had a plumber start a fire in a house 2 years ago, big mess. Convinced me of what I thought I knew, I don,t want to do fire reatoration work. Gabe gives good advise, I would add that you should spray a pigmented shellac BIN is one brand. Shellac seems to seal the odor in the best.
    Steve
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
