I have a flagstone patio which appears to be set on a concrete pad, then attached to the pad grouted with concrete. Need to fill in an area cut out for a rose garden some years ago. Any advice on how to do this — how thick concrete? Is it necessary today? What use to adhere flagstone to concrete? Set stone in wet concrete? Help!
You've got the basics...Zip down to Home Depot...buy a DIY book and concrete and you'll be posting your success here in no time...
Take the risk, and you'll be proud,
J
*Try this, a primer on HTML with links to web design. Courtesy of Dan Morrison, I believe?
I have a flagstone patio which appears to be set on a concrete pad, then attached to the pad grouted with concrete. Need to fill in an area cut out for a rose garden some years ago. Any advice on how to do this -- how thick concrete? Is it necessary today? What use to adhere flagstone to concrete? Set stone in wet concrete? Help!
