try looking up different types of spar varnish or try looking up SIKKENS, its very expensive but has U.V. blocking.
ask around and check out some samples from them (paint stores)
The FHB Podcast crew offers advice on re-insulating the south wall of an old Pittsburgh mill home.
Hi Guys! Thought I would pop over here from fine cooking and ask a couple of questions, you seemed like reasonable folks -
1. I have french doors leading from den onto deck. The outside was finished with stain and then poly ( satin ). After 1 year, the bottoms are badly in need of sanding and refinishing. What should I finish them with this time? Do they just need extra coats of poly? In the summer, they are in full sun and I know that is brutal, too. Help? TIA
2. What is the best way to patch a gyp board ceiling? Any tricks I should know, or just put the piece in per normal? TIA again.
BTW - why haven't you guys checked in at FC for awhile??
*wolverineOn the doors, I would sand them down as much as possible an restain. (it sounda like someone didnt use a good exterior grade poly). Refinish with a good spar varnish. I like McCloskys Boat Coat. Follow the directions on label. It has a Uv inhibitor in it, so it will darken the door a little.How big is the patch in the ceiling?Most of the guys wives wont let the old reprobates back on FC site.Rick Tuk
*Thanks Rick.Patch will be about 18" square. Just enough to annoy me.On the doors - our stain is dark anyway, so that's not a problem. Any brands ( incase I can't find McClosky's ) that I should avoid?? I'ma gonna do it myselfa this time!Send the wives to talk to me - we are friendly, really we are - harmless, too. ;-)
*try looking up different types of spar varnish or try looking up SIKKENS, its very expensive but has U.V. blocking.ask around and check out some samples from them (paint stores)
