Gas pipe in slab
BillBrennen | Posted in Construction Techniques on February 6, 2005 05:11am
Hello All,
A customer wants an island in their kitchen, with an electric cooktop on it. Is on a slab foundation in Southern California, and no utilities to the area, but is within 10 feet of a wall that can bring in the circuit. I am thinking that a trench in the slab, lay conduit to the island, fill in with vinyl patching concrete, and good to go.
However, the customer also wants the option of gas for a cooktop in that same island, for resale purposes. Lots of cooks prefer gas.
Plumber friend says that this is strictly forbidden, no gas in or under a slab in residential construction, period. He was not sure about commercial, but that is beside the point. I don’t have a current plumbing codebook, but the relevant section of my 1994 UPC is a tad vague. The language in section 1211.3 speaks to underground, but not directly to in a slot in a slab. I can see sleeving the section of pipe, but the distant possibility of earthquake rupturing the line may cause them to deny this one.
I have not spoken to a local inspector yet. The project is still in the design phase. Any ideas on this?
Thanks in Advance,
Bill
  1. brownbagg | Feb 06, 2005 05:16am | #1
    nope, big nono. they will put the jail on top of you for this. no gas in slab.
    1. darius | Feb 06, 2005 07:50pm | #6
      Can a gas line be under the slab (1 inch black pipe under the insulation)?
      Edited 2/6/2005 11:53 am ET by Darius
  2. spinnm | Feb 06, 2005 08:07am | #2
    But...as a cook....you can go up and over and bring the pipe down in a column.  Just a thought.
    ShelleyinNM
    1. tab1 | Feb 06, 2005 04:49pm | #3
      Yep, in my last house I brought a gas line in over the top, hiding it in a recess under the trim around a beam.Before I decided to do it myself I had at least 2 "professionals" say to put it in the slab!!!!!!!
      AGHHHHH!
  3. BobKovacs | Feb 06, 2005 05:22pm | #4
    Did it all the time in Las Vegas.  You run a 2" PVC sleeve with long-sweep elbows, and slide corrugated stainless steel gas line thru it.  The PVC needs to terminate around 18" up on a nearby wall, with an access panel to service the connection between the CSST pipe and the black iron gas line coming down the wall.
    Bob
    IMERC | Feb 06, 2005 07:26pm | #5
    add a 1.5 or 2" PVC conduit for a chase for the SS series of gas flex lines..
    use long sweep L's...
    slit the CC to the dirt and set everything a bit deeper... repair with regular CC mix..
    proud member of the FOR/FOS club...
    WOW!!!   What a Ride!
  5. BillBrennen | Feb 08, 2005 06:06am | #7
    Hello Again,
    I spoke with the customer tonight, and she is okay to not have gas, just electric to the island. Thanks for all the speedy replies. If a future owner has to have gas, they can do a drop from the attic in a column at that future time.
    Also, in reply to post #7: No. Gas run under the slab is forbidden. See my first post.
    Bill
Outdoor Lighting
